![]() | Home > My Defender > My Defender rebuild |
steve E Member Since: 06 Mar 2011 Location: Tenby Posts: 2076 ![]() ![]() |
Your such a tease
Looking good so far, can't wait to see its next reincarnation
![]() 90 V8 - Maggie http://www.defender2.net/forum/topic42564.html 110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html 52HG25 lightweight https://www.defender2.net/forum/topic72342.html D3 Hse - Fiona Capri 2l S - Anna Think I might have a problem............ |
Welshsurferdude Member Since: 23 Feb 2012 Location: Newport Posts: 2493 ![]() ![]() |
Try selecting just one pic and make sure its a low ish res or not too big a size?
sorry for the non techy reply ![]() 2015 Discovery 4.5 Black pack Firenze red XS |
steventheplumber Member Since: 29 Apr 2014 Location: Lincolnshire Posts: 767 ![]() ![]() ![]() |
Good postings, looking forward to the rest
Alex1976 Member Since: 24 Jan 2013 Location: Buckingham Posts: 596 ![]() ![]() |
I dropped in a 4HP22 gearbox from Ashcrofts. Very easy when working on a rolling chassis!
smbaker Member Since: 29 Jan 2014 Location: Essex Posts: 5 ![]() ![]() ![]() |
Does the V8 box mate to the 300 backplate without modification? Presumably need new flywheel torque converter etc ?
Looks a v nice build ![]() |
Its a 300tdi box so straight on, but you do need to swap the flywheel for a flexplate and its a different flywheel housing too. Nothing too difficult though.
Next I turned my attention to the rear tub. When I rebuilt it onto the new chassis I didn't do any bodywork, it was just a lift off lift on job. This time I wanted to do a more thorough job and the rear tub was looking a little worse for wear.
The under tub strengtheners were all completely shot. I ordered a complete new set of aluminium top hats (the pieces that run front to back) and new galvanised cross braces from YRM Metal. ![]() Click image to enlarge |
New top hats riveted on ( the originals were spot welded).
And then the cross braces.....
Next I stripped the tub of all its old paint. I wasn't happy with the old paint and so I went down to bare ally to start from scratch.
Stripped it off with industrial paint stripper. Brushed it on and then jet washed it off leaving clean ally. ![]() Click image to enlarge |
Then sprayed it up with my chosen colour I had custom mixed. It is a lovely dark grey with a satin finish.
This was the first body panel to be sprayed so it was a bit of a scary moment to see if the colour and finish would be as I hoped for. ![]() Click image to enlarge |
Next I sprayed up the bulkhead. This is not the original bulkhead, but a brand new TDCi bulkhead that I had modified and then hot dipped galvanised.
So now I don't have vent flaps anymore. I never used them and it is once less place to leak and I can now sound proof and insulate better. ![]() Click image to enlarge |
