Eeshk that's a bad bearing. Thankfully pretty easy and cheap to replace. Replace the belt at the same time and check the tensioner pulley for wear or rough bearings and replace if necessary.
Mine went during my friends wedding whilst driving her to the church... Typical eh?!?!
19th Apr 2016 7:10pm
chopcat
at the moment i have replaced the pulley and have a belt and idler pully to replace as well apart from I cant get the fan off. I have the cranked spanner but cant lock the fan so need to get that 3 hole job
CC
19th Apr 2016 7:12pm
dorsetsmith
also i have used two 30mm x 6mm flat bar with 13mm hole x 2 in one end and 6mm hole x 2 other ends 13mm hole fit over bolt heads on pulley and 6mm bolt too hold the flat bar other end
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
