Home > Td5 > Whats this noise
Page 2 of 2 <12
geobloke
Eeshk that's a bad bearing. Thankfully pretty easy and cheap to replace. Replace the belt at the same time and check the tensioner pulley for wear or rough bearings and replace if necessary.
Mine went during my friends wedding whilst driving her to the church... Typical eh?!?!
Post #525354 19th Apr 2016 7:10pm
chopcat
Wales 2000 Defender 90 Td5 CSW Java Black
at the moment i have replaced the pulley and have a belt and idler pully to replace as well apart from I cant get the fan off. I have the cranked spanner but cant lock the fan so need to get that 3 hole job
CC
Post #525356 19th Apr 2016 7:12pm
dorsetsmith
this out line of holding spanner end
https://www.defender2.net/gallery/albums/u...le0004.PDF
also i have used two 30mm x 6mm flat bar with 13mm hole x 2 in one end and 6mm hole x 2 other ends 13mm hole fit over bolt heads on pulley and 6mm bolt too hold the flat bar other end
Post #525377 19th Apr 2016 8:02pm
Page 2 of 2 <12
