Home > Maintenance & Modifications > Polished Brake Discs
Page 2 of 2 <12
tuesdayfox
2013 Defender 110 Puma 2.2 SW Zambezi Silver
Hi, I was trying to say either get the rotor replaced or machined.
if you want to machine your rotor with sandpapers, the target will be (from workshop manual):
maximal runout is 0.15mm
cheers
Post #525203 19th Apr 2016 8:13am
Caterham
thank you tuesdayfox
Thumbs Up
Post #525204 19th Apr 2016 8:15am
tuesdayfox
otherwise mirror or not, I don't think it is important other than saying your have good braking skills and have recently driven the truck
Post #525205 19th Apr 2016 8:15am
Caterham
I think I'll swap over the calipers and re-assess.
I've just never noticed such a mirror like finish before. Thumbs Up
Post #525207 19th Apr 2016 8:23am
RED-DOT
The friction matierial is the pad not the disc. If the disc was like sandpaper your pads would not last long at all.
You have good discs and if you want to dull them just spray them with brick cleaner or alloy wheel acid based spray.
I would fit new pads which will give you all the braking you will ever need.
PS i think you have seen too many new Audis with the machining marks? 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #525208 19th Apr 2016 8:48am
Caterham
thanks Red-dot.
ps - can anyone confirm the diameter or my rear discs - 296mm.?
many thanks
Post #525210 19th Apr 2016 8:54am
Page 2 of 2 <12
