Home > In Car Electronics > cb antenna on a softop - where?
jst
Any ideas for good range when mounting an antenna on a soft top. Frame for hood is internal and I am not making a hole in the hood. Likewise don't want to drill bonnet.
It could go on the rear quarters on back face above vrn. But range will be limited fwd I believe.
Maybe one of those light bar things at the top of the a pillar ?
Will run sep gnd wire where ever it ends up to help swr. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #522834 10th Apr 2016 6:51pm
I made a mount that bolted into existing holes on the inner edge of the wing, coming under the bonnet and out, with that I worked South America !
Post #522843 10th Apr 2016 7:18pm
Romadog
On my Bowler 100 I used a mirror clamp on a rear bumperette with the firestick antenna I have.
http://www.thunderpole.co.uk/mirror-bar-mo...t-kit.html
http://www.thunderpole.co.uk/medium-cb-ant...k-4ft.html
Post #522859 10th Apr 2016 7:41pm
Penguin
Belgium 2015 Defender 110 Puma 2.2 HT Chawton White
on top of the wing. (If you have checker plates on them) 28/02 - Loss of a good friend...
In a time of chimpanzees, I was a penguin.
Post #522867 10th Apr 2016 7:57pm
jst
thanks so far guys.
How does top of the wing work range wise compared to say on the rear tub above VRN? anyone done any comparisons? Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #522877 10th Apr 2016 8:19pm
dnorrishill
England 2014 Defender 90 Puma 2.2 XS CSW Aintree Green
If you have a puma bonnet they are steel and you use a standard mag mount..
Post #522893 10th Apr 2016 9:07pm
JWL
Here's an idea, might not be of taste but it will work. I used to have a 110 truck cab and a cb, inside the Ifor Williams canopy I stuck an old magnet off an old mag mount on the underside of the Ifor top then used a mag mounted aerial on the top, just make sure that the magnets attract Whistle
If you can clip a plate on the underside of the tilt to the hoop then you're laughing with a magnet underneath, it's impressive to those that don't know when you can swing a magnetic mounted aerial up in the general direction of the magnet underneath and it just stays there just like magic!
I fitted another magnet to enable me to put a magnetic flashing beacon on top for when I was escorting oversize farm kit.
Post #522916 10th Apr 2016 10:55pm
GSLRO
United Kingdom 2002 Defender 110 Td5 CSW Chawton White
How about removing the land rover radio wing top mounted antenna and fitting your cb antenna with a splitter box?
http://www.thunderpole.co.uk/switches-filt...itter.html Adventure isn't paved!
Post #523461 12th Apr 2016 8:13pm
Cupboard
Hey that's a good idea, my CB antenna is good but my radio antenna is pants. I wonder if they work as well as they claim.
Post #523483 12th Apr 2016 9:21pm
jst
All Great ideas, still pondering. Like the metal plate idea, just not convinced on mag mounts for range compared to body mounts. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #523565 13th Apr 2016 8:48am
JWL
The one thing with the magnet to magnet through the tilt idea is that it does really need a physical earth, thinking back I put an earth wire where the aerial attaches to the magnet and taped it to the coax and attached it to the first available earth point.
It's worth it to see poeple trying to work out how a magnet can stay on a non magnetic surface Whistle
Post #523578 13th Apr 2016 9:38am
dgardel
Italy
I'm used to use a magnetic base on Puma (steel) bonnet....... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #523634 13th Apr 2016 1:44pm
Bps
Ffr mount? Thats what I'm going to use along with the fm splitter as someone previously suggested
Post #523643 13th Apr 2016 2:54pm
mikeh501
Mine lives here. It does my FM radio too with a splitter box.
Post #523666 13th Apr 2016 4:56pm
Loz2286
Not heard about these splitter boxes before. I like the idea. Is this what you mean?
http://www.ebay.co.uk/itm/Zetagi-CB-FM-DX2...SwxH1UHXAB 1999 Td5 110 CSW
1961 Series 2 88 LPG
Post #526674 25th Apr 2016 5:26pm
