![]() | Home > In Car Electronics > cb antenna on a softop - where? |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10387 ![]() ![]() |
I made a mount that bolted into existing holes on the inner edge of the wing, coming under the bonnet and out, with that I worked South America !
Romadog Member Since: 07 Jul 2011 Location: Powys Posts: 1750 ![]() |
On my Bowler 100 I used a mirror clamp on a rear bumperette with the firestick antenna I have.
http://www.thunderpole.co.uk/mirror-bar-mo...t-kit.html http://www.thunderpole.co.uk/medium-cb-ant...k-4ft.html |
Penguin Member Since: 08 Dec 2014 Location: Tienen Posts: 247 ![]() ![]() ![]() |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8403 ![]() ![]() ![]() |
thanks so far guys.
How does top of the wing work range wise compared to say on the rear tub above VRN? anyone done any comparisons? Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
dnorrishill Member Since: 15 Jul 2011 Location: Hampshire Posts: 633 ![]() ![]() ![]() |
If you have a puma bonnet they are steel and you use a standard mag mount..
Here's an idea, might not be of taste but it will work. I used to have a 110 truck cab and a cb, inside the Ifor Williams canopy I stuck an old magnet off an old mag mount on the underside of the Ifor top then used a mag mounted aerial on the top, just make sure that the magnets attract
![]() If you can clip a plate on the underside of the tilt to the hoop then you're laughing with a magnet underneath, it's impressive to those that don't know when you can swing a magnetic mounted aerial up in the general direction of the magnet underneath and it just stays there just like magic! I fitted another magnet to enable me to put a magnetic flashing beacon on top for when I was escorting oversize farm kit. |
GSLRO Member Since: 13 May 2012 Location: Tyne and Wear Posts: 499 ![]() ![]() ![]() |
How about removing the land rover radio wing top mounted antenna and fitting your cb antenna with a splitter box?
http://www.thunderpole.co.uk/switches-filt...itter.html Adventure isn't paved! |
Hey that's a good idea, my CB antenna is good but my radio antenna is pants. I wonder if they work as well as they claim.
All Great ideas, still pondering. Like the metal plate idea, just not convinced on mag mounts for range compared to body mounts. Cheers
The one thing with the magnet to magnet through the tilt idea is that it does really need a physical earth, thinking back I put an earth wire where the aerial attaches to the magnet and taped it to the coax and attached it to the first available earth point.
It's worth it to see poeple trying to work out how a magnet can stay on a non magnetic surface ![]() |
I'm used to use a magnetic base on Puma (steel) bonnet....... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
![]() IID Pro MV License |
Bps Member Since: 14 Feb 2016 Location: Lancashire Posts: 847 ![]() ![]() |
Ffr mount? Thats what I'm going to use along with the fm splitter as someone previously suggested
mikeh501 Member Since: 07 Jan 2013 Location: United Kingdom Posts: 1142 ![]() ![]() |
Mine lives here. It does my FM radio too with a splitter box.
Loz2286 Member Since: 31 Aug 2015 Location: High Wycombe Posts: 121 ![]() ![]() |
Not heard about these splitter boxes before. I like the idea. Is this what you mean?
http://www.ebay.co.uk/itm/Zetagi-CB-FM-DX2...SwxH1UHXAB 1999 Td5 110 CSW 1961 Series 2 88 LPG |
