Home > Maintenance & Modifications > The definitive wheel and tyre thread..HOW THEY LOOK
Page 31 of 42 <123 ... 303132 ... 404142>
marsie
England 2010 Defender 110 Puma 2.4 XS CSW Galway Green
15x9 Mach 5 (4" back space) with 33 12.5 15 BFG at. Standard suspension
16" P38 alloys with 285 75 16 BFG Mts (disco 2 axles) standard height suspension
15x10 mach5 deadlock with 36 12.5 15 simex extreme trekker, nothing standard!
Paul 2000 90 TD5,galv chassis, d2 axles ,Bas remap , alisport intercooler , d2 transfer box , side windows-more to come-much more!! *GONE*
2004 110 TD5 Double cab. *GONE*
2010 110 2.4 XS station wagon
Post #519030 29th Mar 2016 8:54pm
I loved that truck of yours Cool
Post #519036 29th Mar 2016 9:00pm
marsie
It was a good old tool, shame i got so busy that i didn't have time to use it Rolling Eyes
Post #519040 29th Mar 2016 9:06pm
Bps
235 85 16 wolfs
295 75 16 off set mods
Karma restored, 35 12.50 15,s back on 😀
Post #522144 8th Apr 2016 10:26am
Arierep
Portugal 1995 Defender 90 300 Tdi SW Alpine White
You guys would do me a great favour if you stopped posting pics of Defenders with 35" tyres...
Bps, how do you like yours with the 35"?
Thanks
Post #522167 8th Apr 2016 11:41am
Bps
Give the choice I wouldn't run anything else. They need a bit of work to get them fitted and not fouling. I'm running a full gwyn Lewis kit. Ome springs and ome +5 shocks. On road I rate km2s. Can hum a bit depending on road surface but that's the least of my worries in a soft top defender. I would only run them on an 8" wide rim. I used to have 10" wide but they caused a handling issue caused by the tread being pulled to flat. Off road they are better than cooper stts although I do like the look of the stt pro but obviously not as good as an extreme pattern simex etc.
I think they suit a 110 and give it the chunky look / stance
Post #522185 8th Apr 2016 12:21pm
Bps
Lost a bit of steering lock as well but with properly set lock stops I've not had any issues
Post #522186 8th Apr 2016 12:23pm
Arierep
Thanks
Do you have HD halfshafts, etc?
Post #522191 8th Apr 2016 12:29pm
Bps
No standard shafts and diffs although 110 has rear Salisbury axle. Had them on my 3.9v8 auto 90 for a while, again with standard shafts etc and didn't have any issues
Post #522206 8th Apr 2016 12:44pm
Arierep
My mate is running 35" on his 300Tdi Disco with Defender transfer case and stock shafts/CVs with no problems also.
I guess problems arise with lockers, but then that's also the case with stock tyres.
Overall do you find them much better than more conservative sizes? How's fuel consumption?
I'm mostly set on 255/85R16 for my next tyres, but each time I see 35"s my mind goes around...
Post #522209 8th Apr 2016 12:52pm
Bps
I measured the fuel consumption in smiles per gallon on the v8 😀 Got 20 mpg taking it easy on a run and down to 13mpg when really enjoying a v8
Not sure in the 110 yet. It's got a 300 tdi in it which was 25-30 on the 235's. With it being ex military it's got the really low ration transfer box in it so with the 35s on its geared it up a bit so it pulls well. If you had a disco transfer box a 300tdi will struggle to pull 35s although a tuned td5 will.
I would hope around 25 mph until I tweak the pump and intercooler but to be honnest fuel consumption has never been high up in my list of prioritys. If it was I wouldn't be driving a 2 ton brick 😀
Post #522220 8th Apr 2016 1:11pm
CDN38
Canada 2000 Defender 110 Td5 SW Bonatti Grey
285/75/16's on Matt Lee Mach 5's.
Very happy with the ride and feel. Trying balancing beads in them, and it's not bad. Sometimes there's a shake at 90kmh, then next time it's at 80kmh, or 110kmh. Being that they are-rebalancing themselves every time after stopping it takes a little getting used to. Overall, I like the fact that I'm not having to deal with adhesive weights coming off all the time.
Hopefully I will be able to get some time over the weekend and finish writing my build thread.
 it's a Landrover thing...
my renovation thread:
http://www.defender2.net/forum/topic40792.html
Post #522283 8th Apr 2016 6:31pm
Simon.pl
Poland 2007 Defender 110 Puma 2.4 HT Keswick Green
Do you use spacers on your Mach 5s, CND38? I think their offset is 10, correct? Yours look more outside than I thought they would be without spacers.
Post #522439 9th Apr 2016 10:50am
CDN38
No spacers. I think it's the angle of the photo that makes them appear a little further out than they are. The fit just inside the fender flair. The usual spray from the front tires, as expected when turning the wheels.
I'll measure the offset. Rim width is 8"
Post #522519 9th Apr 2016 5:45pm
alfajock
United Kingdom 1989 Defender 110 V8 Petrol CSW Bonatti Grey
265/65 18 BFG KO2 on Challenger alloys. ET10 no spacers
 Fully Restored 89 110 CSW V8
CLS 350 CDI for the sensible stuff
Post #522554 9th Apr 2016 7:14pm
