Swac3 Member Since: 21 Feb 2015 Location: Aberdeen Posts: 363 ![]() |
Stuck a full width load bed mat in the back to cover the wheel boxes and a genuine LR dog guard into the Ht. 3 Landrovers
steventheplumber Member Since: 29 Apr 2014 Location: Lincolnshire Posts: 767 ![]() ![]() ![]() |
Did it fit well? Have you got a picture?
The mat or the dog guard? Can post a pic sure no problem 3 Landrovers
The mat, but what the hell the dog guard as well.
srod Member Since: 20 Mar 2015 Location: Argyll Posts: 190 ![]() |
Went up the hill for more wood.
Got this trailer a couple of weeks ago, total impulse buy, thought at the time that i didn't really need it and what the hell was i doing buying it. Have used it just about every day since! ![]() Click image to enlarge |
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Mat needs sticking down at the sides maybe, planning to use that double sided tape carpet fitters use 3 Landrovers |
That looks great, try some high temp spray glue won't move around in our hot summer!
To many tools etc. To see the bottom of my 90! Proper job though looks good |
Fitted a set of new take off boosts and conti's ... Got a euro trip coming up
![]() Billberried the SVX alloys, that stuff is good! I managed to get some new nano wax from BMW - I can confirm it works on land rovers too ![]() |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2767 ![]() ![]() |
Simple outrigger replacement turned into a much bigger job, much happy time with grinder/welder today.
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 11062 ![]() ![]() |
Went out today to do a recce on some green lanes, all worked ok and got home in one piece
Billberried.... That must mean..... euuhh? ![]() Translation for a non native English speaker please? ![]() Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
Eric - it's the name of the alloy wheel cleaning liquid I use, Billberry. Spray on, wait 5 mins, wash off and they look like new
http://www.theultimatefinish.co.uk/valet-p...Gwodkn0A8A |
^^ I see, first was thinking of hillbillies or so and couldn't figure it out.
![]() ![]() Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3347 ![]() ![]() ![]() |
Not today but yesterday...
Journey back to my parents to use the workshop for a engine oil change. All fluids checked and topped up with only the rear diff needing a small top up. Props were greased again and all bulbs checked. My passenger side headlight had stopped working so I assumed it was the bulb, took it apart (which with the light guards is a bit more involved...) and inexplicably started working again, couldn't find the fault, so put it back together. Also adjusted the rear drum brakes because they were feeling a bit slack. They have 2 adjusters on them, one ether side and I couldn't figure out which did which so I adjusted them both and have now got a good brake effort again with no rubbing or hot brakes so can only assume its done correctly? Any pointers would be good ![]() Also fitted a dash cam hard wire kit which has freed up my cigar lighter socket again. Simple kit from Halfords just the usual headache of taking the dash apart and the radio out. Then gave the underside a good pressure wash to get rid of all the salt, mud and road muck accumulated over the winter and then drove back home for dinner. Nice to have a day doing routine stuff sometimes ![]() Self confessed mileage hunter ![]() |
