Home > Maintenance & Modifications > New Switches - Old Dash - inserts?
chopcat
Wales 2000 Defender 90 Td5 CSW Java Black
I have the super harness for the heated seats from Matt and have 2 questions.
Difficult one first.
I would like to use the modern Puma switches which you would normally use in a modern dash with the recesses so the switch sits flush. Does anyone know of somewhere I can get an insert that i can install into the dash then fit the switch into?
Question 2
The harness links into the Puma hazard warning light switch (which i dont have) i am assuming that the three wires taken from there are live/neutral and the white/green = ignition live. Is that right?
Cheers as always
CC
Post #521439 6th Apr 2016 9:21am
dorsetsmith
Puma hazard warning light switch and TD5 hazard warning light switch are same
you pre face lift centre dash ?
Post #521441 6th Apr 2016 9:26am
chopcat
I am that old ....yes
cc
Post #521443 6th Apr 2016 9:36am
dorsetsmith
give my minute
Post #521444 6th Apr 2016 9:38am
chopcat
i haven't got your minute Rolling with laughter
Post #521447 6th Apr 2016 9:41am
chopcat
This is what we need....
http://www.expeditioncentre.com.au/online-...panel.html
now to find one here
Post #521449 6th Apr 2016 9:44am
L90Andy
United Kingdom 1997 Defender 90 300 Tdi ST Nato Green
Firsts Four sell them here:
http://www.firstfour.co.uk/item/2177292/de...tch-bezel- Instagram: L90andy
My 1984 Ninety: http://www.defender2.net/forum/topic56071.html - SOLD!
My 2015 Defender: http://www.defender2.net/forum/topic39625.html - SOLD!
Post #521455 6th Apr 2016 10:03am
Martin
Site Admin
I cut 3 Puma switches into the centre panel but it was a lot of work. Looks great though Wink
There were some 3-bank holders for sale last week: http://www.defender2.net/forum/topic45360.html  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #521458 6th Apr 2016 10:10am
dorsetsmith
this one pre face
this one 2001 to 2015
Post #521459 6th Apr 2016 10:12am
Martin
Site Admin
I'm not sure how your loom is configured and what current it's drawing from its splices behind the hazard switch.
However, both permanent and ignition switched 12V are available behind the centre panel on a pre-2002MY Td5.
Permanent from the lighter (purple with green stripe) and ignition from the rear wiper switch (white with green stripe).  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #521462 6th Apr 2016 10:18am
chopcat
Sorted on the bezels
Thanks DS for the diagrams
Peter at first four is indeed your man for these bezels and i have them on the way
I have mailed Matt who I am sure will confirm the wiring
looking like we are nearly sorted.
if i only had known when i re did me dash last month that i would be buying some heated seats!
Smile
Post #521464 6th Apr 2016 10:19am
PaulMc
As said, they can be bought from FirstFour on their website, or their eBay shop.
They look 'factory' with 2 x Puma heated seat switches in them -
The keyway moulding on the switch's body will need to be removed -
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Paul.
Post #521467 6th Apr 2016 10:28am
The centre panel that Martin cut is made of sliced ham, you're better off starting with a cut bit of alloy!
Post #521478 6th Apr 2016 11:19am
Stiff1
Thanks Martin, I do indeed have a few three switch holders for sale as well as one for the puma hazard switch.
Left over front abandoned project.
I was going to recreate Andy's cubby idea as below but have gone down a different route now.
Anyone wanting inspiration only need read his thread.
Post #521557 6th Apr 2016 3:31pm
