![]() | Home > Camping, Caravanning and Holidays > Painting a sankey do I Red oxside first? |
defender9 Member Since: 12 Mar 2016 Location: Fylde Coast Posts: 1629 ![]() ![]() ![]() |
I wouldn't use Hammerite, its awful stuff, drys too quickly and once dry and hard it chips off easily. I would use a normal brushing enamel from say The Paintman which you can use a roller to apply. As long as the existing paint is sound and well adhered to the steel, I would just flat it down and apply some primer to any bare steel.
muddybaldboy Member Since: 09 Apr 2012 Location: Ruthin Posts: 395 ![]() ![]() ![]() |
Inside and out with Raptor lining.
I'll gladly bring the gear over and help. Just cover bare metal with upol etch primer then blast it on ![]() |
THF Member Since: 18 Jul 2012 Location: Sunny N Hants or Pompey Posts: 83 ![]() ![]() ![]() |
Stacey007,
I got a VGC Mk3 trailer off FleaBay; when living down Plymouth way I took it to a local sand-blaster, (he usually did yacht hulls so fairly gentle). He cleaned the MOD green back to provide a decent key, then Red Oxided it for me. Then I sourced some Chassis Black ( http://www.frost.co.uk/frost-chassis-black-paint.html ) and took it to a local body shop who thoroughly covered it it Chassic Black. I managed to ge this to do the job out of one tin, and pretty much got every nook & cranny. While this was going on I took the tub and got it sprayed to match my 110; all in all it looks pretty dam good. Once I dig some phots off my old mac I'll add them to the post. Can't recommend it enough, that was 2 yrs ago, its stored outside under the original cover (& a little bit of tarp) and it still looks as good!! ![]() Hope it helps! THF |
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3861 ![]() ![]() |
^ Some pictures would be great.
I'm not planning on getting it sand blasted and professionally sprayed though, decided to try to do it myself.. It will live in a garage so I'm lucky in that respect. |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3677 ![]() ![]() ![]() |
spraying yourself in a garage can get great results but ditto from me dont use hammerite it is great on small cast parts but not great on big smooth areas. I would use paints that are suitable for spraying including the primer they are not that much more expensive and the results justify them. DEFENDER 90 TDCI XS,
I hope everyone is well and your land rovers make you happy Last edited by LR90XS2011 on 30th Mar 2016 10:00pm. Edited 1 time in total |
Rosco Member Since: 03 Dec 2010 Location: Burntwood Posts: 1873 ![]() ![]() ![]() |
No need for red oxide, just any primer will suffice, and a top coat/lacquer that is compatible together.
Speak to a local bodyshop supplier and they will helpful and knowledgeable. These guys could be local to you http://www.colourtone.com/ I used hammerite on the chassis of mine and as others have mentioned it dries way to quick to try applying it with a roller, and the outside of the tub painted by a friend of a friend in his garage for roughly £50 IIRC including materials and a drink. [URL=] ![]() Click image to enlarge[/URL] Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() 2002 - Black Discovery II - Gone 2014 - Montalcino Red 110 XS SW |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20967 ![]() ![]() |
Probably Epoxy primer would be most suitable.
If it was Alu which it isn't I don't think? Then Etch. ![]() |
X4SKP Member Since: 29 Nov 2013 Location: Berkshire Posts: 2304 ![]() ![]() ![]() |
Hello Stacy007
I used Smooth Black Hammerite on top of Hammerites Special Metals Primer (Aluminium Floor and Body Panels on a Rapier Trailer) All paint was applied with a roller. Hammerite is the Marmite of Paints for some, but the formula now used changed a few years back and IMO isn't the unforgiving product it once was. I obtained all the paint used free issue from a supplier to our business so this did influenced the decision to use it, results are good enough and can be 'refreshed' as needed depending on how hard a life the trailer has. ![]() Click image to enlarge Good Luck... SKIP https://www.defender2.net/forum/topic83242.html |
Hello
Thanks all, Did you people who have done this sand back right to bare metal everywhere? Or as I have done remove the rusty bits and sand down the flakey paint then prime? Such as this below, partly sanded to bear metal can I prime this whole panel and then top coat? Removing the Nato paint is a pain in the.... and too be honest the majority of it is fine I just want to change the colour... ![]() Click image to enlarge Thanks all |
Hi Stacy007
If it's stuck...leave it stuck, just key the surface, and use an etch primer or special metals primer. The primer is the 'key' here (sorry), any good paint isn't cheap, so surface preparation prior to the top coat is worth it...also choose a warm dry day(s), mine took a weekend to paint when prepared... ![]() https://www.defender2.net/forum/topic83242.html |
Stacey,
As promised: Red oxide post fine sand blasting and sprayed on (Appreciate you intend to brush). ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge The I got it sprayed with Frost's Chassis Black. ![]() Click image to enlarge ![]() Click image to enlarge It leaves a fairly robust finish that retains its shine. I then got the tub painted Oslo Blue and wax oiled the base: ![]() Click image to enlarge Hope it helps you with your plans Jack. |
^ Looking great,
Have you a picture with the sprayed chassis and new top together, Sent a PM ![]() |
