![]() | Home > Maintenance & Modifications > 300Tdi Uprated Intercooler who from?? |
| dave18 Member Since: 11 Jul 2015 Location: Gorleston, Great Yarmouth Posts: 497
L110CDL I have a MadMan EMS2 it's several gauges in one including a Exhaust Gas Temp. Happens to be 'Leeds' company who is the UK distributor
http://www.4x4overlander.com/product/madman-ems2-engine-monitor/ As far as I know my FIO hasn't been touched interesting how you get such a low reading |
| LRmud Member Since: 22 Oct 2014 Location: IV12 Highland Posts: 198
Ebay item no. eBay Item No. 311153075281
£49 + free postage. Drilled a hole in the EGR Blanking Plate, welded bung to plate, fitted to manifold, wired it up - worked first time. -------------------------------------------------------------------------------------------------- 1989 Defender 90 Toyota Aygo & Honda FR-V |
I also have a one box, big(ish) bore exhaust and recently adjusted the tappets. These two things will help keep the temp in check.
Also, sounds so much better than it used to. 1989 Defender 90 Toyota Aygo & Honda FR-V |
| L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 11091
Thanks dave18, nice bit of kit, hav'nt measured mine in any way, was just wondering how easy it was to do so
That a good one as well LRmud
So which is better, a higher number or a lower number, as i said before, i'm a bit dim when it comes to things like this 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
Clayton,
The higher number (temperature) means the engine is burning fuel more efficiently AFAIK. More fuel = more power until you get to about 750 degC when it all potentially starts melting turbo inards, pistons, valves, etc. It's a case of how close you wish to sail to the wind! -------------------------------------------------------------------------------------------------- 1989 Defender 90 Toyota Aygo & Honda FR-V |
Not 100% LRMud. LR says the Tdi should not go above 720 other wise damage will occur normally the exhaust manifold warps first. Also a better burn can actually reduce EGT but there is shed loads that go into it. Fitting a better performing Intercooler and tweeking fueling will bring down the EGT but increase MPG and BHP and Torque!!
Before you start any mods you should really get a base line so get the tappets done fresh oils and filters and drive it see how it feels and if possible see what oil pressure and temp your getting along with boost ( 300Tdi measured at the plenum chamber / manifold should be max 0.9/1 Bar or 14psi ) and EGT. This will let you know if you need to sort anything out first like stuck turbo actuator or leaking air hoses, dirty injectors. Once your happy everything is running right then you can play with bits. The most common and cheapest as it's free is tweeking the Fuel Injection Pump FIP. Then the turbo actuator. Maybe fit a boost pin after that. Then your into uprated Intercooler, Teeeked head and finally Hybrid or VNT turbo. . there is quiet a few things sources about and just because it might not be about a LR Tdi doesn't mean it's wrong as long as it's a Turbo Diesel |
Thanks for both of your answers
