Home > Maintenance & Modifications > 300Tdi Uprated Intercooler who from??
Page 2 of 2 <12
dave18
United Kingdom 1984 Defender 110 300 Tdi CSW Portofino Red
L110CDL I have a MadMan EMS2 it's several gauges in one including a Exhaust Gas Temp. Happens to be 'Leeds' company who is the UK distributor
http://www.4x4overlander.com/product/madman-ems2-engine-monitor/
As far as I know my FIO hasn't been touched interesting how you get such a low reading
Post #517588 25th Mar 2016 6:58am
LRmud
Scotland 1989 Defender 90 300 Tdi HT Baltic Blue
Ebay item no. eBay Item No. 311153075281
£49 + free postage.
Drilled a hole in the EGR Blanking Plate, welded bung to plate, fitted to manifold, wired it up - worked first time. --------------------------------------------------------------------------------------------------
1989 Defender 90
Toyota Aygo & Honda FR-V
Post #517681 25th Mar 2016 2:54pm
LRmud
I also have a one box, big(ish) bore exhaust and recently adjusted the tappets. These two things will help keep the temp in check.
Also, sounds so much better than it used to. Smile --------------------------------------------------------------------------------------------------
1989 Defender 90
Post #517683 25th Mar 2016 2:58pm
dave18
Kool think I will hold off on the exhaust till it either fails ( looks newish) or I get a hybrid or VNT turbo
Post #517690 25th Mar 2016 3:24pm
L110CDL
Thanks dave18, nice bit of kit, hav'nt measured mine in any way, was just wondering how easy it was to do so Thumbs Up Clayton.
Keeper.
Post #518066 26th Mar 2016 10:50pm
L110CDL
That a good one as well LRmud Thumbs Up
So which is better, a higher number or a lower number, as i said before, i'm a bit dim when it comes to things like this Embarassed Clayton.
Keeper.
Post #518069 26th Mar 2016 10:53pm
LRmud
Clayton,
The higher number (temperature) means the engine is burning fuel more efficiently AFAIK.
More fuel = more power until you get to about 750 degC when it all potentially starts melting turbo inards, pistons, valves, etc.
It's a case of how close you wish to sail to the wind! --------------------------------------------------------------------------------------------------
1989 Defender 90
Post #518086 27th Mar 2016 12:28am
dave18
Not 100% LRMud. LR says the Tdi should not go above 720 other wise damage will occur normally the exhaust manifold warps first. Also a better burn can actually reduce EGT but there is shed loads that go into it. Fitting a better performing Intercooler and tweeking fueling will bring down the EGT but increase MPG and BHP and Torque!!
Before you start any mods you should really get a base line so get the tappets done fresh oils and filters and drive it see how it feels and if possible see what oil pressure and temp your getting along with boost ( 300Tdi measured at the plenum chamber / manifold should be max 0.9/1 Bar or 14psi ) and EGT. This will let you know if you need to sort anything out first like stuck turbo actuator or leaking air hoses, dirty injectors. Once your happy everything is running right then you can play with bits.
The most common and cheapest as it's free is tweeking the Fuel Injection Pump FIP. Then the turbo actuator. Maybe fit a boost pin after that. Then your into uprated Intercooler, Teeeked head and finally Hybrid or VNT turbo. . there is quiet a few things sources about and just because it might not be about a LR Tdi doesn't mean it's wrong as long as it's a Turbo Diesel
Post #518204 27th Mar 2016 2:45pm
L110CDL
Thanks for both of your answers Thumbs Up I have had the pump tweaked slightly and got a uprated intercooler on and have got a SS Double S exhaust, from front to back, no middle box on and she really sounds good on tick over Thumbs Up she goes really well Thumbs Up Clayton.
Keeper.
Post #518280 27th Mar 2016 8:42pm
Page 2 of 2 <12
