![]() | Home > Maintenance & Modifications > The definitive wheel and tyre thread..HOW THEY LOOK |
Wild Card 90 Member Since: 03 Dec 2014 Location: Gerlingen Posts: 1060 ![]() ![]() ![]() |
There are probably enough ZUīs somewhere amoungst the 30 pages, but here is another combination.
Gloss black 7x16 ZUīs, 255/85 MTīs, 30mm spacers. ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge 1998 Tdi 90 SW, 2008 Td4 90 SW, 2012 2.2 90 SW, 2" raised Trailmaster/Terrafirma Heavy Track Raids, 255 MTīs, Recaro CSīs, anorak, wellingtons |
CarMan Member Since: 29 Nov 2010 Location: Cotswolds Posts: 1911 ![]() ![]() |
BPMan - the pic is missing? |
Simon.pl Member Since: 15 Mar 2016 Location: Warsaw Posts: 98 ![]() ![]() ![]() |
Has anyone tried 15" x 10" Challenger 5 Spoke -35 steel wheels? Any opinions?
Arierep Member Since: 13 Apr 2013 Location: Portugal Posts: 258 ![]() ![]() ![]() |
-35 offset? Makes my wheel bearings cry just from thinking about it
Lucifus Member Since: 29 Jan 2016 Location: U.K. Posts: 52 ![]() ![]() |
I'm running 16x10 with a -35 offset on my green 110. You'll certainly need extended arches with that width and offset.
familymad Member Since: 13 Dec 2011 Location: Bucks Posts: 3501 ![]() ![]() ![]() |
Who makes that RAI? 1951 80" S1 2.0 1995 110 300TDI 1995 90 300TDI |
Disco_Mikey Member Since: 16 Nov 2014 Location: Dundee Posts: 532 ![]() ![]() ![]() |
![]() Click image to enlarge ![]() Click image to enlarge 18" Boost alloys, 30mm spacers, 285/60 Cooper Zeon LTZ ![]() |
@Jose.Pereira - I've seen many options here with the spacers and different offsets. 30mm spacer is like -30 offset for the bearing - the wheel goes outside - correct? So I don't see any particular reason this should not work.
Extended arches - I agree. I quite like them ![]() ![]() |
Yes a 30mm spacer on a 0 offset wheel gives the same result as a -30 offset wheel.
Yes, that's right. But spacers are usally used with wheels with a +33 offset, resulting in a +3mm OS. Anyway, even a -50mm offset will work, but I'm not sure of the effects of that on wheel bearings. The farther you go from the centerline between the 2 hub bearings the worse it is. How worse and how far, I don't know. But for remote overlanding I would not risk it, of maybe top it at 0mm offset. Maybe a 90 with a lighter gross weight (2550kg) can get away with a wider stance. Anyway, without any objective study, this is all BS |
Nakatanenga.... https://www.nakatanenga.de/fahrzeugtechnik...-ansaugung You can get it through Brendan. It runs through round constant diameter tube, all the way to the air filter. Supposed to be very efficient. 1998 Tdi 90 SW, 2008 Td4 90 SW, 2012 2.2 90 SW, 2" raised Trailmaster/Terrafirma Heavy Track Raids, 255 MTīs, Recaro CSīs, anorak, wellingtons |
Where goes the heater intake?
The intake for the heater is the fixed flap on the side. It acts as a scoop, and at the same time saves the need for a snow cowl. All part of the RAI kit. On a RHD its not required as the heater intake is on the other side.
Wasnīt this a thread about wheels ![]() 2008 Td4 90 SW, 2012 2.2 90 SW, 2" raised Trailmaster/Terrafirma Heavy Track Raids, 255 MTīs, Recaro CSīs, anorak, wellingtons |
You'r right, too much OT.
Let's meet here: http://www.defender2.net/forum/topic45263-15.html |
