Home > Technical > MOT and Defender Seatbelts
Cuthbert
Anyone failed an MOT after catching/marking their seatbelts in the door catch?
Seems a common issue to catch your driver's seat belt on the door catch, attempt to close the door on it and then find it's marked?
Post #513731 13th Mar 2016 12:18am
Not that I've heard of but would depend on the severity of the damage I would suppose. My passenger side is slightly damaged. Rolling Eyes
Post #513733 13th Mar 2016 12:25am
Screbble
Re: MOT and Defender Seatbelts
I had it as an advisory on the MOT when I bought my Landy. It had been an advisory the previous year too. It was definitely a result of the dreaded door striker/catch.
I replaced both - relatively inexpensive and a doddle to fit Thumbs Up
I haven't caught it in the catch since but I don't know if that's because I'm more conscious of doing it (or not doing it) or not f it's that the new belts retract a lot better/quicker.
Post #513739 13th Mar 2016 1:01am
Mash
Guernsey 1998 Defender 90 300 Tdi HT Nato Green
This used to be picked up a lot on the army's equivalent to an mot, we then started to fit seatbelt protectors which did make a big difference in the amount of seatbelts we picked up.
 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
90 V8 - Maggie http://www.defender2.net/forum/topic42564.html
110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html
52HG25 lightweight https://www.defender2.net/forum/topic72342.html
D3 Hse - Fiona
Capri 2l S - Anna
Think I might have a problem............
Post #513791 13th Mar 2016 10:00am
Justtellme
Canada 2003 Defender 110 Td5 SW Oslo Blue
How do these protectors work? Secured around the belt or on the B pillar?
Post #513803 13th Mar 2016 10:25am
Over the belt above the lower fixing:
Post #513824 13th Mar 2016 11:42am
Mo Murphy
If you put a rubber band around the belt and the recliner mechanism, it holds back away from door aperture and saves it getting caught on the striker.
50 Shades of Pennine Grey
Post #513837 13th Mar 2016 1:36pm
Cuthbert
Thanks for the feedback so far - interesting post from Mash regarding the MoD solution. Once again it appears we have had an 'issue' that third parties have provided a 'solution' to.
Be interested to see a posting from one of the forum members who is closer to actually conducting MoT tests?
Post #513910 13th Mar 2016 7:10pm
Flyingfocrs
Scotland 2011 Defender 110 Puma 2.4 USW Santorini Black
Was "advised" to keep an eye on mine at the MOT in January.
Post #513920 13th Mar 2016 7:34pm
EWS
United Kingdom 2006 Defender 90 Td5 HT Alveston Red
Hi.
Fit seat belt pads available from Halfords, ( foam lined and Velcro fixing)and slide them down to where the belt catches against the door catch, probably less then a tenner, as recommended to me by my local indy.
Post #513936 13th Mar 2016 8:14pm
Would they really help - more likely will just get torn up as well as the belt when slamming the door.
Post #513941 13th Mar 2016 8:23pm
EWS
Hi Supercat
I have had these foam sleeves fitted for three years, they covered with some sort of heavy fabric, the proper use is to spread the the load over your shoulder , so I believe. They work a treat, no damage to the sleeves is apparent . they fit by opening them up and velcro back together.
I believe there is a post about these way back in Def 2.
Edward
Post #513946 13th Mar 2016 8:30pm
EWS
Hi Suparcat this is them fitted.
Post #513956 13th Mar 2016 8:54pm
Cupboard
Mine was replaced by the people I bought it from at 13k miles because it was very badly damaged.
I've put 8k miles on to it and never caught the strap in the door.
Post #513967 13th Mar 2016 9:10pm
mk1collector
The mrs caught my passenger one badly and it was flagged as a fail on the mot until my mechanic used a soldering iron on the sticking out bit of material which melted back into the belt, so the mot place passed it. I'm going to replace both of the fronts soon though. Ray
My build thread
Post #514037 14th Mar 2016 12:42am
