Home > Technical > MOT and Defender Seatbelts
Page 2 of 2 <12
apt100
United Kingdom 2016 Defender 90 Puma 2.2 XS CSW Aintree Green
Re: MOT and Defender Seatbelts
Cuthbert wrote:
Anyone failed an MOT after catching/marking their seatbelts in the door catch?
Seems a common issue to catch your driver's seat belt on the door catch, attempt to close the door on it and then find it's marked?
There is a recent thread which might be of interest? http://www.defender2.net/forum/topic34419.html?
Post #514039 14th Mar 2016 12:49am
AndrewS
A few years ago I got both sides of mine changed under warranty, nothing to do with the MOT, car was 2 years old and dealer agreed it was a land rover fault.
Our newer Defenders dot seem to suffer this issue any more, perhaps the return springs are stronger thus stopping the belt from going loose. 130's have feeling's as well you know Smile
Post #514061 14th Mar 2016 7:50am
Screbble
Yes I do think the speed the belts retract into the reel has a lot to do with it.
When I replaced mine I did notice the difference.
Given their primary function, the relative low cost, and the ease of fitting, I'd say it's certainly worth the investment.
I notice there are a couple of reel fixing options so that may also influence things.
And of course the X-Eng door striker plate may help minimise damage (a little?).
Some helpful hints and tips above - thanks Thumbs Up
Post #514308 14th Mar 2016 8:29pm
Pilgrimmick
I had an advisory about ten years ago for the seat belts, but have not had one since, I have not changed them, just some test centres are more pedantic than others. 80" 1948
Lightweight V8
Bowler Tomcat
130 Station wagon
90 300tdi
(Santana PS10 pick up)
Range Rover L322 (Ful fat)
Post #514311 14th Mar 2016 8:39pm
ARC99
I had to change the driver side after getting an advisory three years running, I didn't want to push my luck on a 4 year. Don't make old people mad.
Richard
Post #514365 14th Mar 2016 10:14pm
Mash
Guernsey 1998 Defender 90 300 Tdi HT Nato Green
Found these on the net so you can see the correct fitting:
 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
90 V8 - Maggie http://www.defender2.net/forum/topic42564.html
110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html
52HG25 lightweight https://www.defender2.net/forum/topic72342.html
D3 Hse - Fiona
Capri 2l S - Anna
Think I might have a problem............
Post #514423 15th Mar 2016 12:31am
Page 2 of 2 <12
