Home > Technical > Help please Td5
Page 1 of 3 123>
1963bus
Help please Td5
Hi all
I spotted a drip under my 2002 Td5 dripping off bell housing onto floor, I rushed round all the fluid reservoirs only to find no liquids missing Question
I dried it all up underneath and put some card on the floor, started up and it started dripping again Question Question , caught some in a pot and found it to be diesel Big Cry
I took the engine sound proofing cover off and saw a drip from round the back of the engine, I took a pic from offside looking over wing and have put an arrow from where the drip is coming from [it's behind round thing]
Any idea's please as I know nothing about these engines other than changing the oil/filters etc.
Many thanks
Brian
Post #513549 12th Mar 2016 3:39pm
mk1collector
Fuel pressure regulator, it's quite a common fault. Ray
My build thread
Post #513551 12th Mar 2016 3:42pm
Fatboy Slim
Wales
Fuel pressure regulator leaking
Post #513552 12th Mar 2016 3:42pm
1963bus
Wow that was quick! many thanks for that
May I now ask, is it something that needs tightening up or replacing and is it hard to do? [I can't even see it Embarassed ]
Brian
Post #513553 12th Mar 2016 3:45pm
Fatboy Slim
Wales
You can see it Brian it's just to the right of the green arrow on your picture, with 3 pipes and an electrical connection. 3 x10mm headed bolts holding it on. Me personally, I use the £30 rebuild kits off eBay and have had 100% success with rebuilding them. Some people prefer to chuck a whole unit on for about £120......
Post #513557 12th Mar 2016 3:51pm
1963bus
Thanks again for quick reply, I'll have a look at the re-build kits [I'm not tight but just blown £500 on a personnel number Embarassed ] sod's law something was going to go wrong Laughing
Post #513567 12th Mar 2016 4:18pm
Fatboy Slim
Wales
Nothing wrong with the kits. I'm not tight either but hate waste and I can't see the point of scrapping £100 worth of housing that there's nothing wrong with.
Post #513569 12th Mar 2016 4:23pm
1963bus
Cheers Thumbs Up is it easy to re-build? any special tools?
Post #513572 12th Mar 2016 4:25pm
Fatboy Slim
Wales
A socket set with a 10mm socket and a pair of circlip pliers. Oh and a spanner to undo the return hose if yours is 2002>
Post #513574 12th Mar 2016 4:30pm
1963bus
Many thanks, will give it a go next day off [not dangerous using with a drip is it?]
Kit's seem to start from as little as a tenner, does that sound right?
Post #513580 12th Mar 2016 4:37pm
Fatboy Slim
Wales
Some kits are just a load of 'o' ring seals and a gasket. Look for one that has the little round regulator as well as 100% that's what's leaking
Post #513598 12th Mar 2016 5:41pm
Fatboy Slim
Wales
Ebay iten eBay Item No. 171967832100 try that one
Post #513601 12th Mar 2016 5:41pm
1963bus
Cheers for the link and now watching it Wink
I know it's from Spain but it probably comes from the same place most of the others do [here's hoping]
Thanks for your help, leak scared the hell outa me this morning, now looking forward to the fix Thumbs Up
Brian
Post #513603 12th Mar 2016 5:57pm
Fatboy Slim
Wales
The good news is it's a hell of a lot easier to do on a defender than a disco Laughing Thumbs Up
Post #513604 12th Mar 2016 6:01pm
1963bus
glad I didn't buy one of those then Laughing
Post #513605 12th Mar 2016 6:02pm
Page 1 of 3 123>
