![]() | Home > Maintenance & Modifications > Advice on fitting Nakatanenga Stainless Bolt Kit please :-) |
Nothing too difficult
Bolts are in 10 named bags Put a tarpaulin down so you can easily find a dropped bolt, especially if doing it on grass or gravel One bag at a time. Make sure you have the correct size tool. Use some penetrating oil/lubricant. Undo one bolt at a time and carefully compare them Take your time HTH Brendan |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20915 ![]() ![]() |
I'd recommend WD40 on all bolts the day before you want to change over.
Those you can get at at least. You'll need some paper towels or cloths to throw away for cleaning up any paste and fingers. |
mick Member Since: 08 Feb 2010 Location: Yorkshire Posts: 2109 ![]() ![]() ![]() |
Plenty of copper slip
Edzi Member Since: 20 Sep 2015 Location: London Posts: 279 ![]() ![]() ![]() |
Thanks all, very much appreciated
Kit already comes with anti seize paste. ![]() |
Is there enough ss seems to pick up way to easy these days must be the made in China crap
Ordered some more, just in case
It is your decision whether to put stainless or not, but believe Weicon is a much better "dissimilar metals anti seizing paste" than the Duralac. I have experience with both, and became a convinced believer in the Weicon.
Before somebody will try to start the yea/nay argumentation, just take a look at below, (every day is a school day), and then decide for yourself which route to go with your choice of paste. ![]() Eric http://www.defender2.net/forum/topic38216....p;start=15 http://www.defender2.net/forum/post429871.html#429871 You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
Avelingporter Member Since: 25 Jan 2016 Location: Southampton Posts: 407 ![]() ![]() ![]() |
SS bolts are put in with Tefgel in the marine industry. We did my mates 110DC and after ten years when he needed some work all the bolts we treated were easy to undo!
It is what I will use with the SS bolt kit I got from Brendan. |
^^ Excellent. That is another good option then.
![]() http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
Duralac is designed and made as an inhibitor of electrolytic corrosion between dissimilar materials. It is not an anti seize paste for stainless steel nuts and bolts.
You need a paste with both anti seize and electrolytic corrosion properties. Brendan |
Thanks all for your feedback; much appreciated
![]() Thanks for the info Brendan. So, what's the best product to get, or is there enough supplied with the bolt set? |
Justtellme Member Since: 23 Nov 2015 Location: Ottawa Posts: 310 ![]() ![]() ![]() |
I received about 10 packets of anti seize paste with my bolt kit from Nakatenaga. Looked like normal silver anti seize paste, but not being able to decifer the German on the packets, I'm not sure if the stuff also has dielectric properties??
Did you find the supplied sachets enough? Thanks
