Home > Maintenance & Modifications > Advice on fitting Nakatanenga Stainless Bolt Kit please :-)
Edzi
United Kingdom 2015 Defender 90 Puma 2.2 XS CSW Alaska White
Greetings All,
From all I've read, this seems a straightforward job but as I possess no skills, thought to ask some advice Smile
Any tips or things to watch out for when fitting the stainless steel bolts would be much appreciated.
Does any trim need to be removed or anything tricky need to be done to access nuts etc?!
Once fitted, I then plan on sticking 5mm ball bearings in their heads.
Many Thanks,
Edmond
Post #513346 11th Mar 2016 8:58pm
leeds
Nothing too difficult
Bolts are in 10 named bags
Put a tarpaulin down so you can easily find a dropped bolt, especially if doing it on grass or gravel
One bag at a time. Make sure you have the correct size tool.
Use some penetrating oil/lubricant.
Undo one bolt at a time and carefully compare them
Take your time
HTH
Brendan
Post #513361 11th Mar 2016 9:42pm
I'd recommend WD40 on all bolts the day before you want to change over.
Those you can get at at least.
You'll need some paper towels or cloths to throw away for cleaning up any paste and fingers.
Post #513367 11th Mar 2016 9:54pm
mick
Plenty of copper slip
Post #513368 11th Mar 2016 9:58pm
Edzi
Thanks all, very much appreciated Smile
Post #513369 11th Mar 2016 10:03pm
Kit already comes with anti seize paste. Exclamation
Post #513371 11th Mar 2016 10:11pm
mick
Is there enough ss seems to pick up way to easy these days must be the made in China crap
Post #513383 11th Mar 2016 10:25pm
Edzi
Ordered some more, just in case Smile
Post #513387 11th Mar 2016 10:41pm
ericvv
It is your decision whether to put stainless or not, but believe Weicon is a much better "dissimilar metals anti seizing paste" than the Duralac. I have experience with both, and became a convinced believer in the Weicon.
Before somebody will try to start the yea/nay argumentation, just take a look at below, (every day is a school day), and then decide for yourself which route to go with your choice of paste. Thumbs Up
Eric
http://www.defender2.net/forum/topic38216....p;start=15
http://www.defender2.net/forum/post429871.html#429871 You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #513429 12th Mar 2016 6:22am
Avelingporter
SS bolts are put in with Tefgel in the marine industry. We did my mates 110DC and after ten years when he needed some work all the bolts we treated were easy to undo!
It is what I will use with the SS bolt kit I got from Brendan.
Post #513435 12th Mar 2016 7:45am
ericvv
Post #513437 12th Mar 2016 7:56am
leeds
Duralac is designed and made as an inhibitor of electrolytic corrosion between dissimilar materials. It is not an anti seize paste for stainless steel nuts and bolts.
You need a paste with both anti seize and electrolytic corrosion properties.
Brendan
Post #513465 12th Mar 2016 10:37am
Edzi
Thanks all for your feedback; much appreciated Smile
Thanks for the info Brendan. So, what's the best product to get, or is there enough supplied with the bolt set?
Post #513571 12th Mar 2016 4:24pm
Justtellme
Canada 2003 Defender 110 Td5 SW Oslo Blue
I received about 10 packets of anti seize paste with my bolt kit from Nakatenaga. Looked like normal silver anti seize paste, but not being able to decifer the German on the packets, I'm not sure if the stuff also has dielectric properties??
Post #513578 12th Mar 2016 4:36pm
Edzi
Did you find the supplied sachets enough? Thanks Smile
Post #513584 12th Mar 2016 5:03pm
