Page 55 of 1392 <123 ... 545556 ... 139013911392>
Zinke
United Kingdom 2003 Defender 90 Td5 HT Epsom Green
Fitted a set of Terrafirma shockers today!
Post #51188 5th Jan 2011 7:07pm
BigRuss
Which ones did you go for?? Russell
2011MY 110 XS USW Black
Post #51190 5th Jan 2011 7:12pm
Zinke
Standard all terrain ones, think TS116 and TS117.
Post #51192 5th Jan 2011 7:18pm
Laurie
Lost about 3 gallons of fuel in as many miles when the plastic drain plug thingy on my fuel filter broke.
Main stealers were nearest for a replacement.
Replacement plug - £4
Replacement filter - £43 Shocked Shocked Shocked
Post #51194 5th Jan 2011 7:21pm
DefenderOfTheEarth
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Tonga Green
Admired it but took the BM instead. BRRRRUMM BRRRRUMMM! Defender 110XS SW gone... now VW California 180 4 Motion.
Post #51204 5th Jan 2011 8:30pm
BruceT
South Africa
Travelled the cut lines through Botswana....hope I do this right....
http://www.flickr.com/photos/9885024@N05/5329119875/
(Thanks Glyn - dont know what happened to your post though.)
Post #51299 6th Jan 2011 9:10am
nikk
Malta
beachcombing :)
Beach combing on new years eve Smile.
Post #51312 6th Jan 2011 10:17am
alanhid
Scotland 2006 Defender 90 Td5 XS CSW Bonatti Grey
Great pics Bruce................Im only a little bit jealous (he says as he looks out the window watching the sleety rain fall!)
Same for you Nikk...........looks just like the beach at Ayr!! Life is not a rehearsal!
Def 90td5 CSW xs 2006
Post #51330 6th Jan 2011 11:51am
TC
Re: beachcombing :)
Awesome :thumbsup:
Post #51335 6th Jan 2011 1:25pm
party monkey
England 2005 Defender 110 Td5 XS CSW Cairns Blue
Had BGF AT's fitted to replace the worn out Grabber TR's - bring on some more snow ! Jon - 110 td5 [sold]. Currently Defenderless.
Post #51348 6th Jan 2011 2:55pm
smorland
new fuel filter, fixed a short in the left hand indicators and replaced the cracked surround on the hazard/fog light switch
Post #51501 7th Jan 2011 12:13am
T1G UP
dropped my non charging td5 90 to the auto electricians Big Cry
2 hours later and £20 lighters shes charging Thumbs Up
done a good few miles around Bristol today...up the m5 aswell, got to change the transferbox now as a 1.4 is to low for me.
Post #51502 7th Jan 2011 12:16am
Zinke
Just a quick pic or the rear shocks. On the left is the Terrafirma All Terrain and the right is the standard land rover shock. They both close up to about the same length within a few mm but as you can see they have much more travel.
The fronts are about the same too, which is causing a little problem with keeping the springs in the seats but looking at solutions!
Pete.
Post #51537 7th Jan 2011 1:15pm
alantd
Zinke: wouldn't dislocation cones be your solution?
BruceT: just flicking through some of your historical photos - fantastic. Those shots of the lightning are outstanding. Did you take them? One that started out as a 2.4 TDCi 110 XS
+ New Defender 110 First Edition
Post #51548 7th Jan 2011 2:13pm
Zinke
Think if i just got some spring retainers for the front it will work ok, the front strings arent fixed onto the mount on the axle like the rears are so hopefully this will help and then will get some dislocation cones if there still needed.
Pete.
Post #51550 7th Jan 2011 2:24pm
