Home > In Car Electronics > Not starting, post clutch change. Help!! |
Grenadier Member Since: 23 Jul 2014 Location: The foot of Mont Blanc... Posts: 5765 |
Hello all.
The beast has been in for a clutch change. No major problems, just the usual lengthy process. It was done the 'long' way or the 'proper' way, in from the top, inside the cabin centre console. All reassembled, all apparently fine. But on turning on the ignition, only the Battery Indicator, Odometre and Petrol Guage (and indicator) light up, but absolutely NO response when the key is turned to position three for fire up. No heating element indicator, no turnover or click of the starter, nothing. All terminals on the battery are properly and firmly attached, all electrics seem to be fine (Windows, lights, AC, radio etc) and car locks/unlocks. But position three is dead. We shut all windows, doors etc and locked the cabin from the outside and watched the immobiliser go through a sequence of fast flashes, before a sequence of slow flashes. We left the cabin and doors untouched for 10mins. Disarmed the immobiliser (apparently normal - doors unlock, interior light turns on, four-ways flash). Red immobiliser flasher stops. Key in ignition, turn to Pos2, lights as above come on, still no coil light etc. Turn to pos 3, nothing. We have checked fuses, (but not sure which would be the immobiliser anyway) and re-checked all connections to the battery and those above the clutch that were disconnected during the replacement, including the starter motor wire. Mech thinks it is the immobiliser and either the fuse has gone or the immobiliser needs recalibration but we do not know how. Any thoughts anyone? Heading back tomorrow, so suggestions would be much appreciated. Thanks in advance, I'm sure you have better things to do like being at the pub (unless it has wifi and you're on your phone!!) Monsieur Le Grenadier I've not been everywhere, but it's on my list..... 2011 Puma 110DC - Corris Grey |
11th Mar 2016 7:42pm |
sharkey964 Member Since: 05 Oct 2014 Location: On a muddy track Posts: 570 |
Earth strap from chassis to gearbox?
Marc |
11th Mar 2016 7:46pm |
Effing hell, that's why I love this forum and Defender ownership. A reply in minutes. Thanks Sharkey, will add to check list for tomorrow. Monsieur Le Grenadier
11th Mar 2016 7:48pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19668 |
The above is what I had issues with after clutch change too.
Worth checking them all though. |
11th Mar 2016 7:50pm |
Thanks Steve. Was it what Sharkey Marc suggested or something else? We're leaving it fully locked overnight in case a genie appears or the immobiliser recalibrates, or something else entirely unscientific.... Monsieur Le Grenadier
11th Mar 2016 7:51pm |
Yes, effected the rear loom but had all sorts of random effects!
11th Mar 2016 7:53pm |
Ta Monsieur Le Grenadier
11th Mar 2016 7:54pm |
ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127 |
Happened to me when I did my clutch, no rear lights, abs light on plus allsorts of weird things going on.
It turned out to be one of the ring terminals on the gearbox earth. 80" 80" 86" 88" 90" Wanted, Forward Control Anything considered. |
11th Mar 2016 8:13pm |
Thank you Ian. Added to the list. Monsieur Le Grenadier
11th Mar 2016 8:32pm |
Following on, still no fire up. Done diagnostic and a permanent fault code has come up, U0100. Any thoughts? Monsieur Le Grenadier
12th Mar 2016 10:38am |
Fault code UO100 = Lost comunication with ECM/PCM 'A'
Marc |
12th Mar 2016 12:03pm |
Check ECM plugs are fitted tight, check instrument binicke plug is fitted tight. ( At the rear)
12th Mar 2016 12:57pm |
Thanks Marc/Steve.
Steve, will certainly check, but just for knowledge, would any of that have been touched dypuring clutch change or might this simply be coincidental timing? Monsieur Le Grenadier I've not been everywhere, but it's on my list..... 2011 Puma 110DC - Corris Grey |
12th Mar 2016 1:26pm |
Rickydodah Member Since: 14 Jul 2014 Location: East Sussex Posts: 1091 |
I've heard, can't remember where though, that a similar issue was caused by the connector to the speedometer on the transfer box. This would've have been disconnected when the clutch was changed. I'm at a loss of how this would affect the can-bus as I don't know if this is an input it relies on but it appeared to cause a that guys problem. I started with nothing and still have most of it left!
12th Mar 2016 3:06pm |
