Home > Technical > Sound deadening and Carpet for 110 Utility
rodspink
Hi folks. What are the best options to make my defender a bit quieter and then carpet ontop. Want it to look good especially at the edges and doors. I see Exmoor do an insulated carpet, Is it any good.
Thanks
Rod
Post #512857 10th Mar 2016 5:54pm
LoveTheMud
United Kingdom 2014 Defender 90 Puma 2.2 XS CSW Santorini Black
Hi Rod,
I went to AudioFile in bishops stortford
They used dynamat extreme for the vibration and dynaliner in different thicknesses as a closed cell foam for the noise and heat insulation... i cant tell you how quiet it is... its made a massive difference, even at high speeds (if they can be called that in a defender)
Michael
Post #512862 10th Mar 2016 6:07pm
rodspink
Hi Michael.
Thanks for the reply. Did you put anything on top like carpet, if so how was the fit.
Rod
Post #513076 11th Mar 2016 8:14am
MartinK
A combo of Dynamat and NoiseKiller works for me - now I can talk on the phone at 60mph (hands free of course) Thumbs Up
Noisekiller kit under carpets, and Dynamat on the upper panels in the back. Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #513089 11th Mar 2016 8:51am
rodspink
Nice one thanks for the reply. When you fit the dynamat is it in for good or would it be removable with out much damage to the paint work. Also does it soak up water, Im sure it wont take long for the motor to get its first leak.
Thanks again.
Rod
Post #513181 11th Mar 2016 1:53pm
MartinK
Dynamat does not soak up water - it is sticky-back. The glue may fail with repeated contact with water
However no problems with mine
Dynamat on the sides, NoiseKiller under the carpet, and a Naka loadspace mat (from Brendan aha 4x4 overlander on here)
Also have TGE side panels (where the side windows would be) with Dynamat stuck on the metal behind.
Disco 2 levels of sound now Thumbs Up Perfectly useable. Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #513207 11th Mar 2016 3:05pm
LoveTheMud
the carpets are standard 90 black carpets, they require a little thought as you need to spray both surfaces with the glue so that they stick, its pretty straight forward as far as i'm aware. One thing to note, the thicker the layers being added underneath, the les the carpet will fit...especially around seems and gearboxes etc...
Post #513246 11th Mar 2016 5:13pm
Shame you're not closer
Post #513257 11th Mar 2016 5:40pm
walfy
Looks awesome Matt. I'm intending to dynamat mine, will end up doing it in segments as can't justify doing it in one hit. So I'll make a not of these pics to use for reference Thumbs Up Thumbs Up 110 D250 SE HT
110 USW SOLD
RRE HSE Dynamic Gone, wife killed it
VOLVO XC60 R Dynamic with some toys
Polaris RZR 900XP SOLD
Post #513262 11th Mar 2016 5:48pm
Thank you
Actually we tend to supply a lot more 'Skinz' than 'Dynamat', can't personally tell the difference between them in terms of performance and 'Skinz' is a lot cheaper
Post #513268 11th Mar 2016 6:25pm
walfy
If I'd of given it more thought, I'd of purchased some and asked you to deliver to me a month or so ago when you were passing this way.
I have to come to Kent sometime this year so might save up and make a purchase then Thumbs Up 110 D250 SE HT
110 USW SOLD
Post #513269 11th Mar 2016 6:28pm
rodspink
Excellent guys again thanks for the replying.
Matt obviously Dynamat underneath what is on top the dynamat and did you make your own carpet . If so where did you source it from.
Thanks.
Rod
Post #513270 11th Mar 2016 6:35pm
Hi Rod,
6mm closed cell neoprene on top of the Dynamat (or Skinz), gives a more luxurious feel to the carpet.
The carpet is a high quality automotive / marine item that we buy direct from the manufacturer in bulk.
We don't sell kits or individual pieces, we only offer as a package with sound proofing for installation at our workshops in Kent.
It's the detail that counts - here you can see the barrel sides are carpeted and we trimmed the (customer supplied) 'MUD' side panels in Alston to match the headlining.
We also sound proof and carpet under the bulkhead relocation bar.
Post #513277 11th Mar 2016 6:46pm
This shows a USW that we have sound proofed using Skinz
The rear side panels are sound proofed and then trimmed in Alston
Post #513280 11th Mar 2016 6:52pm
rodspink
Matt.
Thats impressive. As you say we couldn't be further away lol. I will probably do mine in stages and see how I get on. The info and pictures have been great from everyone.
Cheers again.
Rod
Post #513441 12th Mar 2016 8:16am
