![]() | Home > Technical > Sound deadening and Carpet for 110 Utility |
LoveTheMud Member Since: 19 Feb 2015 Location: Weybridge Surrey & Pontefract West Yorkshire Posts: 411 ![]() ![]() ![]() |
Hi Rod,
I went to AudioFile in bishops stortford They used dynamat extreme for the vibration and dynaliner in different thicknesses as a closed cell foam for the noise and heat insulation... i cant tell you how quiet it is... its made a massive difference, even at high speeds (if they can be called that in a defender) Cheers Michael |
rodspink Member Since: 12 Apr 2015 Location: Aberdeenshire Posts: 187 ![]() ![]() |
Hi Michael.
Thanks for the reply. Did you put anything on top like carpet, if so how was the fit. Thanks for the reply. Rod |
A combo of Dynamat and NoiseKiller works for me - now I can talk on the phone at 60mph (hands free of course)
![]() Noisekiller kit under carpets, and Dynamat on the upper panels in the back. Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) |
Nice one thanks for the reply. When you fit the dynamat is it in for good or would it be removable with out much damage to the paint work. Also does it soak up water, Im sure it wont take long for the motor to get its first leak.
Thanks again. Rod |
Dynamat does not soak up water - it is sticky-back. The glue may fail with repeated contact with water
However no problems with mine ![]() Click image to enlarge Dynamat on the sides, NoiseKiller under the carpet, and a Naka loadspace mat (from Brendan aha 4x4 overlander on here) Also have TGE side panels (where the side windows would be) with Dynamat stuck on the metal behind. Disco 2 levels of sound now ![]() |
the carpets are standard 90 black carpets, they require a little thought as you need to spray both surfaces with the glue so that they stick, its pretty straight forward as far as i'm aware. One thing to note, the thicker the layers being added underneath, the les the carpet will fit...especially around seems and gearboxes etc...
Shame you're not closer
[URL=] ![]() Click image to enlarge[/URL] [URL=] ![]() Click image to enlarge[/URL] [URL=] ![]() Click image to enlarge[/URL] [URL=] ![]() Click image to enlarge[/URL] [URL=] ![]() Click image to enlarge[/URL] [URL=] ![]() Click image to enlarge[/URL] [URL=] ![]() Click image to enlarge[/URL] [URL=] ![]() Click image to enlarge[/URL] [URL=] ![]() Click image to enlarge[/URL] [URL=] ![]() Click image to enlarge[/URL] [URL=] ![]() Click image to enlarge[/URL] [URL=] ![]() Click image to enlarge[/URL] [URL=] ![]() Click image to enlarge[/URL] [URL=] ![]() Click image to enlarge[/URL] [URL=] ![]() Click image to enlarge[/URL] Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
walfy Member Since: 29 Aug 2007 Location: Frome Posts: 2698 ![]() ![]() |
Looks awesome Matt. I'm intending to dynamat mine, will end up doing it in segments as can't justify doing it in one hit. So I'll make a not of these pics to use for reference
![]() ![]() 110 USW SOLD RRE HSE Dynamic Gone, wife killed it VOLVO XC60 R Dynamic with some toys Polaris RZR 900XP SOLD |
Thank you
Actually we tend to supply a lot more 'Skinz' than 'Dynamat', can't personally tell the difference between them in terms of performance and 'Skinz' is a lot cheaper |
If I'd of given it more thought, I'd of purchased some and asked you to deliver to me a month or so ago when you were passing this way.
I have to come to Kent sometime this year so might save up and make a purchase then ![]() 110 USW SOLD RRE HSE Dynamic Gone, wife killed it VOLVO XC60 R Dynamic with some toys Polaris RZR 900XP SOLD |
Excellent guys again thanks for the replying.
Matt obviously Dynamat underneath what is on top the dynamat and did you make your own carpet . If so where did you source it from. Thanks. Rod |
Hi Rod,
6mm closed cell neoprene on top of the Dynamat (or Skinz), gives a more luxurious feel to the carpet. The carpet is a high quality automotive / marine item that we buy direct from the manufacturer in bulk. We don't sell kits or individual pieces, we only offer as a package with sound proofing for installation at our workshops in Kent. It's the detail that counts - here you can see the barrel sides are carpeted and we trimmed the (customer supplied) 'MUD' side panels in Alston to match the headlining. We also sound proof and carpet under the bulkhead relocation bar. [URL=] ![]() Click image to enlarge[/URL] Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
This shows a USW that we have sound proofed using Skinz
The rear side panels are sound proofed and then trimmed in Alston [URL=] ![]() Click image to enlarge[/URL] Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
Matt.
Thats impressive. As you say we couldn't be further away lol. I will probably do mine in stages and see how I get on. The info and pictures have been great from everyone. Cheers again. Rod |
