![]() | Home > Maintenance & Modifications > Rear Wiper |
DAZ110 Member Since: 06 Dec 2007 Location: East Sussex Posts: 2061 ![]() ![]() |
Yes
driver9 Member Since: 15 Oct 2012 Location: Suffolk Posts: 111 ![]() ![]() ![]() |
Managed to change the wiper blade on my Puma without removing the wheel.
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2228 ![]() ![]() ![]() |
You should be able to change the blade without removing the wheel, but to do the arm it's a wheel off job
Birdy Member Since: 07 Oct 2011 Location: Côte d'Azur Posts: 885 ![]() ![]() ![]() |
I've never been able to do it without removing the wheel, even if you switch the ignition off when the arm is in the vertical position.
Peter |
Stiff1 Member Since: 09 Dec 2014 Location: Cornwall Posts: 602 ![]() ![]() ![]() |
That is what I am finding.
RRUK Site Supporter Member Since: 31 Mar 2010 Location: Leicestershire Posts: 2028 ![]() ![]() |
I swapped mine to a Bosch Aerotwin flat blade, but had to remove the rear wheel to get at it properly. 2016 D4 HSE
1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 SWB Petrol |
With most of the spare wheel carriers this small problem just disappears.
Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
