Home > Maintenance & Modifications > Best DRL controllers
Cheshire110
So I've had a couple of DRL controllers, and many of them seem to be utter rubbish.
Either poor build quality or trying to do far too many things.
I just want one that will last 15 years and turn the lights on with engine, and off with the sidelights.
Any recommendations?
Cheers Cheers, David
Post #512104 8th Mar 2016 5:55pm
rustyboxx
United Kingdom 2015 Defender 90 Puma 2.2 CSW Montalcino Red
How about the old fashioned solution using relays? 2015 90 XS CSW TDCi - Beautiful
2007 110 XS DCPU - An itch that needed scratching
2005 90 Td5 XS CSW - Utterly brilliant
2001 Discovery 2 ES Auto - A phase I went through
1996 90 Tdi CSW - Uber reliable
1989 90 2.5 Petrol Hardtop - My first proper Landy
1985 Range Rover Vogue V8 -Troublesome
Post #512115 8th Mar 2016 6:12pm
Cheshire110
Still need to get them on with the engine somehow, and hard to waterproof... Cheers, David
Post #512117 8th Mar 2016 6:14pm
MuddyChris300tdi
United Kingdom 1995 Defender 130 300 Tdi HCPU Alpine White
I don't know a lot about electrics, but am thinking of fitting some drl's. Could you use a relay and instead of having 12v feed switch it on, could you use a feed from head lights to turn the relay off.
And could you get the drl's to come back on with main beam?
Post #512158 8th Mar 2016 7:50pm
ericvv
Relays to control DRL just work perfect on mine for about 4 or 5 years now. My DRL come on with "contact on" (so before actual engine starting), go off with parking lights or higher. Some will like them to just dim with parking lights or higher, but as I reverted back from LED headlights to my standard SVX Wipac halogens I prefer the DRL to remain off when front lights are switched on. The relays currently are placed high up under the hood, but later this summer all the cabling, relays, etc. will be replaced by and relocated to a new aux electric panel. That is not only for the DRL of course, all other relays like those for the fog lights, of the upgraded headlights wiring loom, etc. will be relocated then and centralised in this panel. Will be more waterproof than anywhere under the hood I think. Laughing
Eric
 You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #512200 8th Mar 2016 9:28pm
