![]() | Home > Maintenance & Modifications > Best DRL controllers |
Cheshire110 Member Since: 26 Jul 2013 Location: London Posts: 2789 ![]() ![]() |
So I've had a couple of DRL controllers, and many of them seem to be utter rubbish.
Either poor build quality or trying to do far too many things. I just want one that will last 15 years and turn the lights on with engine, and off with the sidelights. Any recommendations? Cheers Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
Still need to get them on with the engine somehow, and hard to waterproof... Cheers, David
MuddyChris300tdi Member Since: 02 Mar 2014 Location: Derby Posts: 225 ![]() ![]() ![]() |
I don't know a lot about electrics, but am thinking of fitting some drl's. Could you use a relay and instead of having 12v feed switch it on, could you use a feed from head lights to turn the relay off.
And could you get the drl's to come back on with main beam? |
ericvv Member Since: 02 Jun 2011 Location: Near the Jet d'Eau Posts: 5817 ![]() ![]() ![]() |
Relays to control DRL just work perfect on mine for about 4 or 5 years now. My DRL come on with "contact on" (so before actual engine starting), go off with parking lights or higher. Some will like them to just dim with parking lights or higher, but as I reverted back from LED headlights to my standard SVX Wipac halogens I prefer the DRL to remain off when front lights are switched on. The relays currently are placed high up under the hood, but later this summer all the cabling, relays, etc. will be replaced by and relocated to a new aux electric panel. That is not only for the DRL of course, all other relays like those for the fog lights, of the upgraded headlights wiring loom, etc. will be relocated then and centralised in this panel. Will be more waterproof than anywhere under the hood I think. ![]() Eric ![]() Click image to enlarge You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
