Home > Technical > spigot rings
Page 1 of 3 123>
Penguin
Belgium 2015 Defender 110 Puma 2.2 HT Chawton White
spigot rings
Anyone knows where I could find spigot rings, so pre 2007 wheels can fit a post 2007 defender.
it's 114.6mm to 124mm
thx 28/02 - Loss of a good friend...
In a time of chimpanzees, I was a penguin.
Post #511877 8th Mar 2016 8:04am
Lambley
United Kingdom 2006 Defender 90 Td5 HT Java Black
Are you sure your right? All wheels after 1990 should have the same bore size, I don't think they've changed at all?
Post #511883 8th Mar 2016 8:32am
Penguin
100% Wink
Since 2007 they are 114.6mm instead of 124mm 28/02 - Loss of a good friend...
Post #511884 8th Mar 2016 8:33am
Martin
Site Admin
I've got 1997 wheels on my 2015 Defender and they fit straight on. No spigot rings or adapters, nothing.
The diameter of the drive flange (which is the equivalent of where a spigot ring goes on a normal hub) is exactly the same, no change.
There's no mention on here of spigot rings - only spigot bearings for the clutch - and the only Google result for "Defender spigot 114.6mm" is this thread!!
I think you have some misinformation.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #511917 8th Mar 2016 10:34am
Penguin
Indeed, older wheels will fit newer defenders, but not the way around.
But did you measure your 2015 wheel hub?
http://www.wheel-size.com/size/land-rover/defender/2015/
http://www.wheel-size.com/size/land-rover/defender/2007/
http://www.defendersource.com/forum/f6/hub...58414.html 28/02 - Loss of a good friend...
Post #511922 8th Mar 2016 10:41am
Martin
Site Admin
An older wheel would indeed fit but it would be loose on the drive flange, and I would not fit loose wheels!
That site is wholly and completely wrong, there is no difference.
If you want proof...
Drive member 1993 to 2007: FTC859 replaced by RUC105200
Drive member 2007 to 2016: RUC105200
That is impossible if the drive flange diameter changed.
They have also not made two different types of the Wolf/HD wheels which change at 2007. They are all ANR4583PM (tubeless, primed for paint)
The before 2007 Boost alloy is RRC110870MNH replaced by RRC502000MNH replaced by RRC503400MNH replaced by LR023391
The after 2007 Boost alloy is RRC503400MNH replaced by LR023391
So all Boost alloys are now LR023391
This is also impossible if there is a change at 2007 Wink  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #511924 8th Mar 2016 10:53am
Penguin
I'll send you a photo while measuring the axle.
I wanted to fit ZU wheels first, it was while searching for reviews and possible balance issues I came upon a post of a the diameter change.
Not OZ, but ZU 28/02 - Loss of a good friend...
Post #511927 8th Mar 2016 10:57am
Martin
Site Admin
Well aftermarket wheels can be whatever centre bore they like Wink  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #511930 8th Mar 2016 11:06am
Penguin
well, I hope I'm wrong, cause in that case they will have to take back the wheels... 28/02 - Loss of a good friend...
Post #511931 8th Mar 2016 11:07am
I have fitted a Series 1 wheel to an '07 Defender while swapping wheels round and it is a perfect fit. There is no difference in centre size.
Post #511946 8th Mar 2016 11:34am
shaggydog
You haven't changed your drive flanges have you? Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Self confessed mileage hunter Very Happy
Post #511948 8th Mar 2016 11:35am
Penguin
no I didn't.
It's a 2015 defender.
This bothers me...
I'll be heading home to measure and to be sure. 28/02 - Loss of a good friend...
Post #511949 8th Mar 2016 11:36am
dave18
United Kingdom 1984 Defender 110 300 Tdi CSW Portofino Red
Errrmmmm As said only two sizes, Early and Late!! Unless you have HD Drive flanges fitted which sometimes need the edges radiused to prevent them fouling.
Post #511956 8th Mar 2016 11:55am
Penguin
As we say in Flemish: Meten is weten:
Original wheel fitted when purchased i nJune 2015 -> 114.6 will be correct
The new wheels
So the new wheels have a center bore of 124, my originals 114.6
As said, there is a difference after 2007.
numbers on the original wheels:
6H12-1007 - 80 5½Jx16 x33 Tubeless MWro 13 15 696
So these will NOT fit a pre 2007 defender 28/02 - Loss of a good friend...
Post #511989 8th Mar 2016 1:37pm
shaggydog
But they are steel wheels they don't center on the spigot anyway they center on the wheel nuts so why does it matter?
Also your new wheels look like aftermarket 8 spokes so they will be different. They go over the drive flange and can be bolted up so what is the issue?
My aftermarket modulars are not tight on the center ether and that is on a truck a long time prior to 2007 and I have fitted post 2007 hd wolf wheels onto it as well with no issue.
Or have i got the wrong end of the stick? Dog Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #511994 8th Mar 2016 1:46pm
Page 1 of 3 123>
