![]() | Home > Technical > Who wants a Nanocom Evolution |
parktag Member Since: 30 Sep 2008 Location: Brittany Posts: 366 ![]() ![]() ![]() |
Email sent
![]() 98 V8 Disco |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5108 ![]() ![]() ![]() |
We should all be good (thanks)
aaronmorris Member Since: 03 Sep 2010 Location: doncaster Posts: 62 ![]() ![]() ![]() |
sent you an email peter
walpoleer Member Since: 03 Jan 2011 Location: Walpole st Andrew Posts: 7 ![]() ![]() ![]() |
cheers Peter, great service thanks just starting out and getting it all wrong..so I'am told, and have a disco 2 but thats not an option as it was the wife choice. and she has never known herself to be wrong.
Just a quick question,
Is the nanocom unit to be uses as well as or instead of the scanurgauge?? I see that they do similar things but the nanocom is much bigger. Also it the nanocom is to replace the scanurgauge where do you plan on mounting it? Russell 2011MY 110 XS USW Black |
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 ![]() |
Russell, the scangauge is fitted in my landy permanently to monitor water temp, air temp etc and reset any fault codes to get me home if the need arises. Due to its size it is ideal compared to mounting the nanocom which as you say is much bigger. The scangauge is just a very handy and cheap scan tool, as you cannot change anything in the ecu with it. The nanocom is a very different beast as it allows programming of key fobs, injectors etc. Also goes into more detail in monitoring vehicle systems than the scangauge to allow fault finding. I personally would not leave this in the vehicle mounted as you can bypass the alarm and immobiliser with it meaning a scrot in the know could hotwire your landy and be away with it. (Admittedly the alarm would sound until bypassed) Will look into this more once I get the OBDII splitter cable as it is a right royal pain just now disconnecting the scangauge to allow the nanocom to be fitted
Thanks to both Peter and Brian for sorting this unit Mike
CFB Member Since: 13 Sep 2007 Location: Bradford, West Yorkshire Posts: 803 ![]() ![]() |
Mine just arrived but I can't register or unlock it as the webpage isn't working
Just refresh and try again...mine did that Mike |
Nope, refreshed it a dozen times but no go, have emailed Peter Andy
Got it to register by just putting the product code and email address in, if I tried to add my name/address etc it didn't work Andy
Mine arrived today, found the same, the registration only worked with the minimum required fields filled in E-Mail and product code, the password arrived in my inbox within a couple of minutes, thanks again to Peter and Brian for getting this set up. just starting out and getting it all wrong..so I'am told, and have a disco 2 but thats not an option as it was the wife choice. and she has never known herself to be wrong. |
Seems we all have Nancoms now
I'm having major problems with mine, its
![]() Have emailed Peter again for help ![]() PS. Has anyone tried to upgrade the firmware as I have been unable to do so Andy |
