|  | Home > Maintenance & Modifications > Wheel Bearing Maintenance Puma 2012 |
| thor44 Member Since: 18 Sep 2015 Location: Ahrntal, Südtirol Posts: 128    | Hi, I've recently stumbled upon a pretty good instructional video:
 . _____ .|_____\___ [|_/-\__/-\_|} ...(O)....(O)........ MY14 2.2 Defender 90 SW | ||
|  29th Feb 2016 7:51am |
| defendercouple Member Since: 13 Jan 2016 Location: Sydney Posts: 4      | Thanks Thor44,
 That video is great instructional help, particularly if I need to replace bearings rather than just repack. Does anyone know if the seal must be replaced with a new one for a repack? If so I will need to find a part number and track a pair down before I get into this  | ||
|  29th Feb 2016 9:20pm |
| Alien Member Since: 18 Jan 2015 Location: Bacchus Marsh Posts: 230    | You'll find the seals will get damaged on removal so replacement is necessary.
 Don't forget to have some sealant for the drive flanges on hand( I use RTV). Loctite the drive flange bolts after a good clean of the threads, some folk replace the bolts but I change them every 2nd strip down. All the specs you need and more look like they are on this thread from a site a few off us are also members on... http://www.aulro.com/afvb/90-110-130-defen...tting.html Don't forget to grease the axle-drive flange splines after inspecting for damage. I use Castrol High Temp wheel bearing grease on mine, same for the axle-flange and on my trailer wheel bearings. If your retaining the single stack nut you will need to replace them too. I use the 2 nut system with the original spacer and just do every thing up tight as no need to set preloads... http://www.defender2.net/forum/topic42034.html Cheers, Kyle. | ||
|  1st Mar 2016 3:25am |
| defendercouple Member Since: 13 Jan 2016 Location: Sydney Posts: 4      | Many thanks Kyle,
 That answers all my remaining questions. | ||
|  4th Mar 2016 4:56am |
| Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2789    | If you haven't slotted the brake pipe bracket then you'll need to disconnect it and therefore bleed it on reassembly. Slot it when apart so you don't have to do it in the future.
 Drive flange gasket as above and keep an oil seal too in case you damage it on removal of the hub. | ||
|  4th Mar 2016 7:54am |
| Posting Rules
