![]() | Home > Puma (Tdci) > Won't turn over. Cant connect to OBD. No main beam/dip |
| RED-DOT Member Since: 29 Jun 2009 Location: stirling Posts: 2363
Starter motor failure. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
| Soupy Member Since: 05 Dec 2014 Location: Aberdeen Posts: 68
Hi, thanks for the reply.
Is that likely to cause multiple issues then? |
| Cupboard Member Since: 21 Mar 2014 Location: Suffolk Posts: 2971
Hopefully this should link to a wiring diagram:
https://onedrive.live.com/?id=4BC2D89C85C7...9C85C7C171 Sounds to me like the supply to the ignition switch - does the dash "turn on" when you turn the key on? The OBD won't work until the ignition is turned on and the sidelights will work but no headlights until the ignition is turned on either. |
| Noiseydave Member Since: 27 Dec 2015 Location: West Midlands Posts: 43
Has similar on a 2008 90
Turned out to be ignition switch and a relay under the drivers seat but i can not remember which one |
Got there in the end.
Fitted a new starter (£150 Hooked the hawkeye to the AS10, there were about 5 immobilisers listed, one of which was enabled. Disabled it and she fired. Can connect to the ECU now too. Just the headlights to go |
| Supacat Member Since: 16 Oct 2012 Location: West Yorkshire Posts: 11018
Did you fit the new starter yourself?
Given you had no power to the lights, I would have expected a garage to investigate that before swapping out a starter motor. Not tried to do it on a Puma engine but could not not have ruled the starter motor out insitu by using jumper cables directly to it from your battery. OK the fuel pump and other systems may have prevented the engine starting but the starter motor may have kicked into life? |
Ford starters are made of cheese and over worked. I reckon only a pickpocket could successfuly hit the +ve terminal without a firework display? Sorry if i misdiagnosed your fault. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Fitted myself. I upgraded to a Bosch starter anyway so no problem really.
The fault came back!! Got to the bottom of it (hopefully). Bad earth! |
F****** M*****F******* Piece of F****** S***
Won't start again!! The temp gauge has gone shooting up and it won't turn over!!! |
Sorted phew!
Some wally (i.e. me) hadn't got the wires seated on the starter properly making a bad connection. Got it now though! |
AAAAAAAAAAAAAAARRRRGH!!!
Came in again this morning, won't turn over. Only dash light is the battery and the temp gauge shoots off the scale! |
| dorsetsmith Member Since: 30 Oct 2011 Location: South West Posts: 4554 |
check all the earth connection
All (all the ones I could find anyway) are clean and tight.
under driver seat is starter motor relay third one from bulk head end one side of the coil feed from ignition switch and other from ECU ind switch feed from link 5 60 amp red arrow see if this relay orange arrow is clicking then you try to start the engine if not, wiring, fuse or ECU stopping relay from operating and starter from tuning
see diagram below Click image to enlarge YWB500060 part number from the this relay (spec for the relay is 12volt 40 amp) if the relay is operates do you have multimeter to check volts out to the starter sol ? see diagram below Click image to enlarge |
