Home > Puma (Tdci) > Won't turn over. Cant connect to OBD. No main beam/dip
Page 2 of 2 <12
Soupy
The relay does nothing. Nada. If I jump a wire across it I can get the starter to turn over but not run. Also the dash is still skew whiff.
I tried all the relays out of my other tdci which I know to be working. No improvement.
I think I might remove the ECU and check the wires to it and earth next....
Post #510718 4th Mar 2016 5:11pm
dorsetsmith
you jump a wire across power side ok can you tell if power is getting too coil from ignition switch side i would test the relay out of the socket i had relay fail i.e. coil open cct also check switch side of the relay too
Post #510721 4th Mar 2016 5:24pm
Soupy
That's me officially out of ideas. Banging Head
Removed the ECU, checked all connections and earths etc. Ran some new ones direct to the battery earth. Still nowt.
Taking it to a local Land Rover Specialist tonight. Hopefully won't cost too much.
Post #511643 7th Mar 2016 3:00pm
DAZ110
Hope you get it fixed without to much cost. Let us know what the problem was when you get it sorted.
Post #511658 7th Mar 2016 4:39pm
Soupy
So, the independent LR specialist fixed it. (Bow down Kirkstyle garage in Kemnay Aberdeenshire).
Dodgy wiring somewhere. No way I'd have managed to fix it myself. I went round while he was at it, he had all sorts of electronic gizmos attached to the vehicle. No parts needed just a length of wire.
Post #516787 22nd Mar 2016 4:28pm
Rickydodah
Brilliant Very Happy I started with nothing and still have most of it left!
Post #516794 22nd Mar 2016 5:01pm
dorsetsmith
good Thumbs Up ( independent LR Aberdeenshire specialist to rememder ) Exclamation
Post #516806 22nd Mar 2016 6:28pm
Page 2 of 2 <12
