Home > Maintenance & Modifications > fitting a NAS rear step
potspeedy
Romania 2012 Defender 110 Puma 2.2 SW Orkney Grey
I have this Nakatanenga wheel carrier. Considering this, how easy is to fit a NAS rear step?
Post #508558 26th Feb 2016 10:04pm
leeds
Normally the question is will the Nakatanenga wheel carrier fit with a NAS step.
The answer is yes to a genuine NAS step, although the main bracket of the wheel carrier might need a firm push down behind the rubber of the NAS step. Sometimes the rubber step needs a slight trimming.
Fitting a genuine NAS step should be straightforward.
HTH
Brendan
Post #508565 26th Feb 2016 10:17pm
X4SKP
Hello potspeedy
I have a NAS Rear Step with a Mantec Spare Wheel Carrier...(which also fits)
Looking at your photo, and what looks like your Dixon Bate Adjustable Slider / Tow Hitch,
which will fit to the NAS Step but will require some creative metalwork to brace at the lower
section of the set-up as the whole assembly projects further back from the cross member /
chassis with the NAS Step fitted...one additional thing to think about... Shocked
 SKIP
Post #508592 26th Feb 2016 11:24pm
mk1collector
As your naka wheel carrier is the earlier type it take quite a bit of modification of the wheel carrier bracket as I found when I fitted mine.
I had to take even more off than this Ray
My build thread
Post #508609 27th Feb 2016 1:18am
theorangebandit
If you're not afraid of a grinder and a lick of spray then it'll fit. I made my nas style step fit to my nak single arm, made similar cuts to the above post. More needs a trim to seat it flush but its on the list of things to do 👍
Post #508611 27th Feb 2016 3:37am
potspeedy
Thanks guys.
Well, I'm not afraid of a bit of grinding...I will order an Nas step and fit it but that's my last concern now as I had to take out the engine... I will make a separate post about.
Post #508649 27th Feb 2016 10:33am
