- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
Yannis
Ciao,
I just received a nice BlackVue dashcam
What is the best way to get the wire up behind the headlining just above the windscreen? If I need to remove the headlining, how do I do this?
My plan is to run the wire in the headlining above the screen, then down the side to enter the top of the dash where I will hard wire it in my upcoming electrical project.
Yan[/s]
25th Feb 2016 1:50pm |
Happyoldgit
I generally cables up by taping them to a length of stiff wire [a straightend out coathanger for example]. By rermoving the trim from the windscreen frame, removing the interior light and it's locating bracket you can then use the stiff wire to feed the cable to where you want it.. Steve.
http://forums.lr4x4.com
25th Feb 2016 2:24pm |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
