![]() | Home > Technical > Rattle - prop shaft, or not?? |
Are the flanges tight on the diff and transfer box?
I had a rattle on overrun for a while and also looked at the driveshafts and it happened to be the rear flang off the transferbox that had a little play. It was only visible with the handbrake drum attached with the drum off I knew it had to be there but hardly could see it. I tightend the nut and the rattle is gone. (for now ![]() 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
srod Member Since: 20 Mar 2015 Location: Argyll Posts: 190 ![]() |
Thanks - that's got to be worth a look. Will check that and report back.
Just need to wait for a break in the weather, driveway has just turned into a small lake. |
To close the case on this...
Worn front shock absorber bushes, picked up at the MOT. Replaced and rattle gone! And there I was about to rebuild the front diff ![]() |
