![]() | Home > Maintenance & Modifications > Plastic Hinge Caps Set Defender 110 |
Michaels Defender Member Since: 16 Aug 2007 Location: North Yorkshire Posts: 282 ![]() ![]() ![]() |
Has any one fitted these yet?, possibly a good idea to protect the hinges from corrosion and
there is also a short bumper cover, which could be used as a number plate mount http://www.exmoortrim.co.uk/store/hofele/l...etail.html http://www.exmoortrim.co.uk/store/hofele/l...etail.html ![]() Click image to enlarge |
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3865 ![]() ![]() |
Never seen them before but I like the idea as its either change all the bolts to help prevent corrosion or 'out of sight out of mind'
Would have to colour code them but they look smart in the pictures.. Something else to add to my spreadsheet of stuff I like.... thanks ![]() |
I have put ball bearings in the hinges as a theft deterrent, so to avoid any future rust this would protect them I guess
Michael |
Are the bolts was easy to change as the rear cross member ones?
o4dn Member Since: 08 Jan 2010 Location: South West Posts: 591 ![]() ![]() ![]() |
I reckon these are a very bad idea, would be a perfect mud/moisture trap so that rust can work his way safely hidden behind...
... and at that price, plastic caps ![]() ![]() -- 2009 2.4 Puma Defender 90 SW 1979 Land Rover Series 3 88" |
williamthedog Member Since: 29 Dec 2012 Location: south wales Posts: 3441 ![]() ![]() |
I think that they would go brittle after a while as well.
Not the best idea |
If you take them out one by one they are easy yes |
![]() Click image to enlarge The actual hinge element seems to be still open to the elements from this photo of one fitted. |
As said, only vulnerable part is the pin,which isn't protected with this.Save your money and just wash it frequently.I painted over my bolts wi black metal chassis paint anyways,took 2 minutes,bolts haven't rusted in 2 years,I bet they don't rust within 10 years either. Pov.spec,ftw. 2006, 110,TD5.
Just can't see the point unless you adhere to the out of sight out of mind ethos. Steve.
