Home > Maintenance & Modifications > Plastic Hinge Caps Set Defender 110
Michaels Defender
United Kingdom 2013 Defender 110 Puma 2.2 ST Corris Grey
Has any one fitted these yet?, possibly a good idea to protect the hinges from corrosion and
there is also a short bumper cover, which could be used as a number plate mount
http://www.exmoortrim.co.uk/store/hofele/l...etail.html
Post #507829 24th Feb 2016 10:57pm
RoddyK05
Scotland 2004 Defender 90 Td5 SW Yellow
At a ton plus the dreaded, no, I have not tried them. If my screws get manky, I'll just replace them and save myself a large wedge in the process.
Post #507834 24th Feb 2016 11:07pm
Stacey007
Never seen them before but I like the idea as its either change all the bolts to help prevent corrosion or 'out of sight out of mind'
Would have to colour code them but they look smart in the pictures..
Something else to add to my spreadsheet of stuff I like.... thanks Very Happy
Post #507835 24th Feb 2016 11:10pm
Michaels Defender
I have put ball bearings in the hinges as a theft deterrent, so to avoid any future rust this would protect them I guess
Michael
Post #507839 24th Feb 2016 11:12pm
Stacey007
Are the bolts was easy to change as the rear cross member ones?
Post #507840 24th Feb 2016 11:13pm
o4dn
France 2009 Defender 90 Puma 2.4 SW Alaska White
I reckon these are a very bad idea, would be a perfect mud/moisture trap so that rust can work his way safely hidden behind...
... and at that price, plastic caps Shocked Shocked “A Land Rover immobilized is a moral defeat for the driver and bad publicity for the vehicle, […] it's up to you to do justice to your Land Rover!” - Land Rover Driving Technique.
2009 2.4 Puma Defender 90 SW
1979 Land Rover Series 3 88"
Post #507897 25th Feb 2016 9:14am
williamthedog
I think that they would go brittle after a while as well.
Not the best idea
Post #507913 25th Feb 2016 10:15am
williamthedog
If you take them out one by one they are easy yes
Post #507914 25th Feb 2016 10:17am
Re: Plastic Hinge Caps Set Defender 110
The actual hinge element seems to be still open to the elements from this photo of one fitted.
Post #507961 25th Feb 2016 12:11pm
jimbob7
As said, only vulnerable part is the pin,which isn't protected with this.Save your money and just wash it frequently.I painted over my bolts wi black metal chassis paint anyways,took 2 minutes,bolts haven't rusted in 2 years,I bet they don't rust within 10 years either. Pov.spec,ftw. 2006, 110,TD5.
Post #507966 25th Feb 2016 12:21pm
Happyoldgit
Just can't see the point unless you adhere to the out of sight out of mind ethos. Steve.
http://forums.lr4x4.com
Post #508032 25th Feb 2016 2:29pm
