Home > Puma (Tdci) > Gearbox Breather?
Kevzeboy
United Kingdom 2011 Defender 110 Puma 2.4 USW Indus Silver
Gearbox Breather?
Can someone advise me on where to find the gearbox breather on my tdci?
Thanks.
Kevin.
Post #507097 22nd Feb 2016 9:50pm
Rickydodah
No 6 in diagram I started with nothing and still have most of it left!
Post #507108 22nd Feb 2016 10:06pm
Kevzeboy
Thank you.
Post #507125 22nd Feb 2016 10:24pm
ter11
Switzerland 2007 Defender 90 Puma 2.4 SVX Station Wagon Santorini Black
Great! I am also looking for the breather of the Transfer Gearbox. Anyone such a picture where I could identify this other breather pipe?
Best regards!
Ter
Post #507447 23rd Feb 2016 10:33pm
Rickydodah
No 13 on diagram, if you remove chubby box if fitted and plate beneath, it's right underneath. Thumbs Up I started with nothing and still have most of it left!
Post #507475 23rd Feb 2016 11:06pm
tuesdayfox
2013 Defender 110 Puma 2.2 SW Zambezi Silver
there is only ONE breather for both Transfer box and Gearbox, right?
as I have only extended one from them ...
cheers
Post #507512 24th Feb 2016 3:28am
ter11
Thanks Rickydodah!!!
Post #507589 24th Feb 2016 1:33pm
cheers
Not exactly. The gearbox breather 'breathes' into the bellhousing. The transfer box breather is a traditional pipe.
Post #507611 24th Feb 2016 2:27pm
tuesdayfox
The breather for gearbox can be extended
But you will need to remove the gearbox
I guess do it with a clutch job
Post #652058 22nd Sep 2017 12:18pm
HardCharger
In the diagram, there is a tube connected to the part number 13, what may that be? And how do we plumb an extended hose to this?
Post #652199 23rd Sep 2017 4:59am
zsd-puma
The transfer box and axles are already extended into the engine bay from the factory, you'll find them next to the heater. someone might have been in there and tucked them out of the way, but if they've not been extended far enough for your needs you can just add to the ends of the pipes in the engine bay.
I reckon with a bit of contortionism, it should be possible to cut the gearbox breather hose and just extend that too.
Post #652201 23rd Sep 2017 5:25am
