![]() | Home > Puma (Tdci) > Gearbox Breather? |
Kevzeboy Member Since: 19 Jul 2014 Location: Cumbria Posts: 87 ![]() ![]() ![]() |
Can someone advise me on where to find the gearbox breather on my tdci?
Thanks. Kevin. |
Rickydodah Member Since: 14 Jul 2014 Location: East Sussex Posts: 1091 ![]() |
![]() Click image to enlarge No 6 in diagram I started with nothing and still have most of it left! |
Thank you.
![]() Click image to enlarge No 13 on diagram, if you remove chubby box if fitted and plate beneath, it's right underneath. ![]() |
tuesdayfox Member Since: 23 Jun 2013 Location: Sydney,OZ Posts: 129 ![]() ![]() |
there is only ONE breather for both Transfer box and Gearbox, right?
as I have only extended one from them ... cheers |
ter11 Member Since: 28 Oct 2015 Location: Zurich Posts: 26 ![]() ![]() ![]() |
Thanks Rickydodah!!!
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17852 ![]() ![]() ![]() |
Not exactly. The gearbox breather 'breathes' into the bellhousing. The transfer box breather is a traditional pipe. |
The breather for gearbox can be extended
But you will need to remove the gearbox I guess do it with a clutch job Cheers |
HardCharger Member Since: 03 Mar 2013 Location: Manila Posts: 778 ![]() ![]() ![]() |
In the diagram, there is a tube connected to the part number 13, what may that be? And how do we plumb an extended hose to this? |
zsd-puma Member Since: 09 Aug 2016 Location: Kent Posts: 2720 ![]() ![]() ![]() |
The transfer box and axles are already extended into the engine bay from the factory, you'll find them next to the heater. someone might have been in there and tucked them out of the way, but if they've not been extended far enough for your needs you can just add to the ends of the pipes in the engine bay.
I reckon with a bit of contortionism, it should be possible to cut the gearbox breather hose and just extend that too. |
