![]() | Home > Technical > boarding roof rack |
BIGFOG Member Since: 12 Sep 2010 Location: Edenbridge Posts: 537 ![]() ![]() ![]() |
Think there is something called 'trailer board' that has a slightly raised surface pattern for extra grip, never tried it but it may work??
leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8584 ![]() ![]() |
Question is why do you want to board a roof rack?
Extra weight up top which reduces your carrying capacity Think one of the trade names is Buffalo board Brendan |
Mark_110DCPU Member Since: 26 Jul 2010 Location: West Sussex Posts: 78 ![]() ![]() ![]() |
Mine has been done with galvanised weld mesh - 2" square mesh - rather than board. It means you can walk on it safely without falling through, it spreads the load across the whole rack, but does not have the same aerodynamic effect as plywood.
just a thought Mark [:O|===|O:] 2001 110 TD5 Doublecab |
double cab happy Member Since: 01 Jun 2009 Location: merseyside Posts: 573 ![]() ![]() ![]() |
i would surgesrt that ply would have less of an aero effect, bicycle wheels are none to create turbulance many times wider than the wheel, but it would be lighter so i guess it may even out. |
pom Member Since: 01 Jun 2010 Location: Worcester Posts: 1343 ![]() |
on the plus side it should improve your MPG as a board would create lift making the motor weigh less.
![]() Pom |
Smudge Member Since: 12 Dec 2010 Location: Hampshire Posts: 10 ![]() ![]() ![]() |
I used 'Buffalo Board' on mine (http://catalogue.chilterntimber.co.uk/category2070625.html). You can get it from most timber supplies. Depending on how much gap you have between the bottom of the rack and the landy's roof, you might have to put some large (about 2") holes in the buffalo board, or an air-dam at the front of the rack. Smudge 2007 110 XS CSW Stornoway Grey |
TC Member Since: 21 Nov 2010 Location: Gloucestershire Posts: 715 ![]() ![]() |
LMAO |
