Home > Technical > boarding roof rack
joetetley
United Kingdom 1995 Defender 110 300 Tdi SW Epsom Green
boarding roof rack
Hi what is the best sheet material to use on my galvanised roof rack to form its base
many thanks
Post #50674 1st Jan 2011 11:53pm
BIGFOG
United Kingdom 2009 Defender 110 Puma 2.4 USW Stornoway Grey
Think there is something called 'trailer board' that has a slightly raised surface pattern for extra grip, never tried it but it may work??
Post #50676 2nd Jan 2011 12:01am
leeds
Question is why do you want to board a roof rack?
Extra weight up top which reduces your carrying capacity
Think one of the trade names is Buffalo board
Brendan
Post #50679 2nd Jan 2011 12:17am
Mark_110DCPU
United Kingdom 2001 Defender 110 Td5 DCPU Chawton White
Mine has been done with galvanised weld mesh - 2" square mesh - rather than board. It means you can walk on it safely without falling through, it spreads the load across the whole rack, but does not have the same aerodynamic effect as plywood.
just a thought
Mark [:O|===|O:] 2001 110 TD5 Doublecab
Post #50681 2nd Jan 2011 12:45am
double cab happy
England 2007 Defender 110 Puma 2.4 DCPU Java Black
just a thought
Mark
i would surgesrt that ply would have less of an aero effect, bicycle wheels are none to create turbulance many times wider than the wheel, but it would be lighter so i guess it may even out.
Post #50704 2nd Jan 2011 2:26pm
pom
on the plus side it should improve your MPG as a board would create lift making the motor weigh less. Thumbs Up
Pom
Post #50706 2nd Jan 2011 2:39pm
Smudge
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Stornoway Grey
Re: boarding roof rack
many thanks
I used 'Buffalo Board' on mine (http://catalogue.chilterntimber.co.uk/category2070625.html). You can get it from most timber supplies. Depending on how much gap you have between the bottom of the rack and the landy's roof, you might have to put some large (about 2") holes in the buffalo board, or an air-dam at the front of the rack.
Smudge 2007 110 XS CSW Stornoway Grey
Post #50720 2nd Jan 2011 4:41pm
TC
Pom
LMAO
Post #51055 4th Jan 2011 9:51pm
