![]() | Home > Technical > Drag link |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2750 ![]() ![]() |
Should be straight yes.
srod Member Since: 20 Mar 2015 Location: Argyll Posts: 190 ![]() |
There are two bends in mine! So much so it looks like it has been formed like that intentionally, rather than as a result of a prang. But so slight I couldn't see the advantage or reason over a straight section. Probably been bent and attempted to be restraightened in the past.
I guess I'll replace it, wonder what else I shall find upstream ![]() |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20919 ![]() ![]() |
Is it lifted at all or was possibly at some point?
I looks as though it's all as it was originally and has never been modified.
But I've only owned it for the past 1 of it's 13 years, so I couldn't be 100% sure! |
Ruts etc. can bend them when off-road. Especially if it is not the original, the aftermarket track rods are ridiculously easy to bend as they are made of the finest Chinese cheese metal.
Replaced mine with a Sumo bar from Gwyn Lewis after tiring of straightening it after every green lane outing. |
Yep replace them with updated ones, using a lot of copper slip on the new ball joints
![]() 90 V8 - Maggie http://www.defender2.net/forum/topic42564.html 110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html 52HG25 lightweight https://www.defender2.net/forum/topic72342.html D3 Hse - Fiona Capri 2l S - Anna Think I might have a problem............ |
