![]() | Home > Technical > Drag link |
| Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2789
Should be straight yes.
| srod Member Since: 20 Mar 2015 Location: Argyll Posts: 190 |
There are two bends in mine! So much so it looks like it has been formed like that intentionally, rather than as a result of a prang. But so slight I couldn't see the advantage or reason over a straight section. Probably been bent and attempted to be restraightened in the past.
I guess I'll replace it, wonder what else I shall find upstream |
| custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21044
Is it lifted at all or was possibly at some point?
I looks as though it's all as it was originally and has never been modified.
But I've only owned it for the past 1 of it's 13 years, so I couldn't be 100% sure! |
Ruts etc. can bend them when off-road. Especially if it is not the original, the aftermarket track rods are ridiculously easy to bend as they are made of the finest Chinese cheese metal.
Replaced mine with a Sumo bar from Gwyn Lewis after tiring of straightening it after every green lane outing. |
| Mash Member Since: 09 Feb 2015 Location: Guernsey Posts: 1674
Yep replace them with updated ones, using a lot of copper slip on the new ball joints
| All times are GMT |
