![]() | Home > Puma (Tdci) > Is there only one EGR valve gasket? |
Just taken my EGR valve off (what a job that was! 2 hours to do 4 bolts!) and as I pulled it out various things clattered on to the floor but I've only found a gasket for the inlet side. When I say inlet, I mean the side that faces the bulkhead with the larger bolts.
Is that correct or has the other gasket vanished somewhere in to my engine bay? The lower bolt was a complete PITA because there's a hose clip in the way that makes lining a socket up incredibly difficult. I know it specifies a torque value but I'd never get a torque wrench in there ![]() |
Answer:
There are two gaskets, one for either side. I've found it ![]() Now to stick it all back in again! |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20921 ![]() ![]() |
I've been there done that, bloody things they are.
Putting it all back together again was much easier! The gaskets were a bit of a faff but valve in, bolts, electrics, bonnet, tidy up took less than an hour. Much better.
And away she went and the workshop disappeared in a white cloud ![]() I have to say it's much easier if you take the bonnet off. No way I could get at anything from underneath. It would be a whole lot easier if there wasn't a hose clip in the way of the bottom bolt! And for something that's so often replaced why they couldn't have put it somewhere a bit more accessible I don't know. |
Eau02467 Member Since: 20 May 2015 Location: Glasgow Posts: 48 ![]() ![]() |
Bust off the hose clip n replace with a jubilee clip, it makes the job a lot easier as you can access the bolt from below. Also next time the jubilee clip is easy to remove to get it out the way
