Home > Puma (Tdci) > Is there only one EGR valve gasket?
Cupboard
Just taken my EGR valve off (what a job that was! 2 hours to do 4 bolts!) and as I pulled it out various things clattered on to the floor but I've only found a gasket for the inlet side. When I say inlet, I mean the side that faces the bulkhead with the larger bolts.
Is that correct or has the other gasket vanished somewhere in to my engine bay?
The lower bolt was a complete PITA because there's a hose clip in the way that makes lining a socket up incredibly difficult. I know it specifies a torque value but I'd never get a torque wrench in there Confused
Post #504278 13th Feb 2016 2:21pm
Cupboard
Answer:
There are two gaskets, one for either side. I've found it Smile
Now to stick it all back in again!
Post #504289 13th Feb 2016 3:29pm
I've been there done that, bloody things they are. Thumbs Up
Post #504309 13th Feb 2016 5:07pm
Cupboard
Putting it all back together again was much easier! The gaskets were a bit of a faff but valve in, bolts, electrics, bonnet, tidy up took less than an hour. Much better.
And away she went and the workshop disappeared in a white cloud Rolling with laughter pretty sure that's not supposed to happen! We'll see what happens now. There was a load of black stuff in it but I've given it as best a clean as I could.
I have to say it's much easier if you take the bonnet off. No way I could get at anything from underneath. It would be a whole lot easier if there wasn't a hose clip in the way of the bottom bolt! And for something that's so often replaced why they couldn't have put it somewhere a bit more accessible I don't know.
Post #504324 13th Feb 2016 5:43pm
Mines tuned with EGR closed so I don't have to worry about the things which is a godsend.
They have got expensive too.
Thumbs Up
Post #504347 13th Feb 2016 7:39pm
Eau02467
Bust off the hose clip n replace with a jubilee clip, it makes the job a lot easier as you can access the bolt from below. Also next time the jubilee clip is easy to remove to get it out the way
Post #504367 13th Feb 2016 8:49pm
