Home > In Car Electronics > Grey plug under cubby
Page 2 of 2 <12
integrale
New Zealand
Removed the cubby and panel on my 90 Heritage and found what appear to be three unused connector blocks.
Anyone able to identify their purpose? Suspect two plugs are for the unused (NZ spec) DPF wiring - what's the third for?
Post #504184 13th Feb 2016 2:26am
From closest to the gear levers:
C3692 - Sensor-Temperature-Exhaust gas-2 - Pre catalytic converter temperature sensor
C3691 - Sensor-Temperature-Exhaust gas-1 - Post DPF exhaust gas temperature sensor
C3693 - Sensor-Temperature-Exhaust gas-3 - Post catalytic converter temperature sensor
although sensor 2 &3 may be wrong as orientation of diagram is uncertain.
Post #504284 13th Feb 2016 3:04pm
Re: Grey plug under cubby
JDH wrote:
Is it a plug and play connector for a factory fit alpine sub?
How you getting on with this?
By chance, I found this old post, which seems to suggest that it may not be plug and play:
http://www.defender2.net/forum/topic21305.html?highlight=alpine
Post #505775 18th Feb 2016 12:14pm
JDH
United Kingdom 2012 Defender 90 Puma 2.2 HT Santorini Black
Hi Supacat, sadly have been busy with work to chase it up too much, land rover have no idea what plugs into it or what plug I'm even talking about and i can't seem to find a sub with a plug like that anywhere on the internet! like i said last time i really don't understand how they have no idea what it is, it must have been fitted in the factory unless the fairys put it there... Rolling Eyes Confused
Post #506195 19th Feb 2016 6:40pm
HossBog
I've got one as well, just in front of the cubby...
Seems to point 'forwards' towards if you know what I mean... 2002MY Defender 90 H/T
Post #506846 21st Feb 2016 10:59pm
JDH
Hi BossHogg
Yours is a different plug all together! that is a diagnostics plug on a td5 Thumbs Up
Post #506898 22nd Feb 2016 9:25am
Martin
Site Admin
Correct, diagnostic plug. You can tell by the trapezoid shape.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #506927 22nd Feb 2016 11:47am
HossBog
Super, at least I know what my plug is for now.. Wink 2002MY Defender 90 H/T
Post #507564 24th Feb 2016 11:45am
xrodney
 2015 Defender 110 Puma 2.2 USW Santorini Black
cannot see original images.
I had a look and did not see the gromet and wires. should I have a look below that metal plate?
Post #1037291 13th Jun 2024 11:53am
Page 2 of 2 <12
