![]() | Home > In Car Electronics > Tapping into the interior light circuit.... HELP! |
| Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6735
OK if you don't want dimming then add the relay
Edit: your diagram is OK 1988 90 Td5 NAS soft top
2015 D90 XS SW |
| mcma1 Member Since: 16 Oct 2012 Location: Northern Ireland Posts: 2947
Great, thanks! Andy
2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
| Cupboard Member Since: 21 Mar 2014 Location: Suffolk Posts: 2971
This on on a 90? That extra load will be no problem, just use a permanent live and the switched ground from the 10AS.
I think I'd be reluctant to use a relay, depending on the relay it might chatter when the dimming starts. Does anyone know what sort of interior lighting the Discovery 1&2 had? |
A 110 mate so 4 lights... yes when the roof lights dim, these should remain on, will that work, does the 10AS switched ground remain after the dimming? Andy
Ah right, in that case you would be wise to use a relay. If you were talking about a 90 hardtop with only one interior light then adding a bit to it wouldn't matter, but a 110 it's under heavier load anyway.
Plumb the relay in to the existing interior light circuit across the permanent live and switched ground. When you open a door it will switch on, it will then remain on for a time after you shut the door and half way through dimming (all being well) it will turn off. The only thing is it might buzz for a bit during the dimming. Sorry about all the confusion! |
I think i will try my circuit and see what happens...What size of in line fuse should i use? Andy 2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
Yes, your circuit is using the existing permanent live and switched ground out of the 10AS to control the relay. If they're 3W bulbs and you've got 4, then that's 12W or 1A. So something small! Or just piggyback off the permanent 12V to the current interior lights, don't need a fuse then because it's already fused.
Great, I will tap into the existing permanent to the lights then Andy
Last question,
For this type of job can i just use 5amp cable then? Andy 2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
Ok I tested this and yes as it dims the relay buzz's for a few seconds... Any way around this? Andy
Can I wrap it in foam and try to insulate the sound it make just?? Andy
5A cable would be fine so long as it's fused properly. If you're using the current 10A fuse then you should be fine, cable rated for 5A will blow a 10A fuse if there's a fault. Belt and braces would be to put in another 5A fuse.
Buzzing... no, there's nothing you can do about it. The lights are dimmed by something called PWM - pulse width modulation. Basically there are some electronics that turn the power on and off very quickly, so quickly that you can't see it. When it's dimming there comes a time when the off pulses are too long for the relay to stay energised and the on pulses are long enough for it to re-energise. It's not very good for either the relay or the control circuit. What would I do? Get some low current LEDs for all your interior lights (they're not very expensive) and your door lights. Do away with the relay, just wire them all in direct. You'll be using less current than the original system used and you can do away with any relays, additional complications etc. Simples. I used the bigger one from these guys but it's if anything a bit too bright. This is the smaller one: http://www.outbound4x4.co.uk/shop/exterior...light-bulb Your current lights will be drawing something like 750mA each, the "big" LED unit is about 170mA so if I guesstimate the smaller one at 100mA, changing the three internal lights for three of them will leave plenty of spare to power your 3W door lights. Warmer white lights are available too. |
All sorted!!!
I tried another relay I have in the defender spares drawer, and all is quiet! Working a treat... Only had 8 amp cable and tapped into the interior light wires and I didn't have an in line fuse anyway... Thanks for the help! Andy 2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
| Leeroy Member Since: 01 Aug 2015 Location: East Yorkshire Posts: 261
mcma1
Looking forward to seeing the end result its a great thread Cheers Leeroy |
Some thing odd now though!!
The instrument cluster lights are not working!! They light up etc but the likes of the handbrake light and coil light done come on...??? Andy 2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
| All times are GMT |
