Home > In Car Electronics > Tapping into the interior light circuit.... HELP!
Page 3 of 4 <1234>
Martin
Site Admin
OK if you don't want dimming then add the relay Thumbs Up
Edit: your diagram is OK Smile  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #502648 9th Feb 2016 3:12pm
mcma1
Post #502649 9th Feb 2016 3:15pm
Cupboard
This on on a 90? That extra load will be no problem, just use a permanent live and the switched ground from the 10AS.
I think I'd be reluctant to use a relay, depending on the relay it might chatter when the dimming starts.
Does anyone know what sort of interior lighting the Discovery 1&2 had?
Post #502661 9th Feb 2016 3:45pm
mcma1
A 110 mate so 4 lights... yes when the roof lights dim, these should remain on, will that work, does the 10AS switched ground remain after the dimming? Andy
2014 Fuji 110 SW LS3
https://www.defender2.net/forum/post751233.html#751233
2014 Corris 110 SW
http://www.defender2.net/forum/topic40056.html
My old Xtech 90 build..
http://www.defender2.net/forum/topic15681.html
LS3 V8 build...
http://www.defender2.net/forum/topic49051.html
Post #502663 9th Feb 2016 3:47pm
Cupboard
Ah right, in that case you would be wise to use a relay. If you were talking about a 90 hardtop with only one interior light then adding a bit to it wouldn't matter, but a 110 it's under heavier load anyway.
Plumb the relay in to the existing interior light circuit across the permanent live and switched ground. When you open a door it will switch on, it will then remain on for a time after you shut the door and half way through dimming (all being well) it will turn off. The only thing is it might buzz for a bit during the dimming.
Sorry about all the confusion!
Post #502712 9th Feb 2016 5:08pm
mcma1
Big Cry
I think i will try my circuit and see what happens...What size of in line fuse should i use? Andy
2014 Corris 110 SW
LS3 V8 build...
Post #502717 9th Feb 2016 5:30pm
Cupboard
Yes, your circuit is using the existing permanent live and switched ground out of the 10AS to control the relay. If they're 3W bulbs and you've got 4, then that's 12W or 1A. So something small! Or just piggyback off the permanent 12V to the current interior lights, don't need a fuse then because it's already fused.
Post #502765 9th Feb 2016 7:11pm
mcma1
Great, I will tap into the existing permanent to the lights then Andy
2014 Corris 110 SW
LS3 V8 build...
Post #502768 9th Feb 2016 7:15pm
mcma1
Last question,
For this type of job can i just use 5amp cable then? Andy
2014 Corris 110 SW
LS3 V8 build...
Post #502777 9th Feb 2016 7:25pm
mcma1
Ok I tested this and yes as it dims the relay buzz's for a few seconds... Any way around this? Andy
2014 Corris 110 SW
LS3 V8 build...
Post #503539 11th Feb 2016 6:08pm
mcma1
Can I wrap it in foam and try to insulate the sound it make just?? Andy
2014 Corris 110 SW
LS3 V8 build...
Post #503542 11th Feb 2016 6:09pm
Cupboard
5A cable would be fine so long as it's fused properly. If you're using the current 10A fuse then you should be fine, cable rated for 5A will blow a 10A fuse if there's a fault. Belt and braces would be to put in another 5A fuse.
Buzzing... no, there's nothing you can do about it. The lights are dimmed by something called PWM - pulse width modulation. Basically there are some electronics that turn the power on and off very quickly, so quickly that you can't see it. When it's dimming there comes a time when the off pulses are too long for the relay to stay energised and the on pulses are long enough for it to re-energise. It's not very good for either the relay or the control circuit.
What would I do? Get some low current LEDs for all your interior lights (they're not very expensive) and your door lights. Do away with the relay, just wire them all in direct. You'll be using less current than the original system used and you can do away with any relays, additional complications etc. Simples.
I used the bigger one from these guys but it's if anything a bit too bright. This is the smaller one:
http://www.outbound4x4.co.uk/shop/exterior...light-bulb
Your current lights will be drawing something like 750mA each, the "big" LED unit is about 170mA so if I guesstimate the smaller one at 100mA, changing the three internal lights for three of them will leave plenty of spare to power your 3W door lights. Warmer white lights are available too.
Post #503674 11th Feb 2016 10:16pm
mcma1
All sorted!!!
I tried another relay I have in the defender spares drawer, and all is quiet! Working a treat... Only had 8 amp cable and tapped into the interior light wires and I didn't have an in line fuse anyway...
Thanks for the help! Andy
2014 Corris 110 SW
LS3 V8 build...
Post #503705 11th Feb 2016 10:53pm
Leeroy
United Kingdom 2016 Defender 110 Puma 2.2 Adventure Phoenix Orange
mcma1
Looking forward to seeing the end result its a great thread Thumbs Up Thumbs Up Thumbs Up
Leeroy
Post #503785 12th Feb 2016 9:05am
mcma1
Some thing odd now though!!
The instrument cluster lights are not working!! They light up etc but the likes of the handbrake light and coil light done come on...??? Andy
2014 Corris 110 SW
LS3 V8 build...
Post #503790 12th Feb 2016 9:17am
Page 3 of 4 <1234>
