Home > Maintenance & Modifications > After-market seat options.
Riccarton
Scotland 2012 Defender 90 Puma 2.2 HT Zambezi Silver
What do those of you do that fit seats without removable bases? In particular what mods are made so you can, for example, access the jack easily on a dark rainy night when you get a flat miles from anywhere?
There's quite a few seats I've seen that I like the look of but the removable base is there for a reason and it would irk me continuously if I fitted something that wasn't right!!!
Post #502356 8th Feb 2016 9:59pm
JAY BOY
Wales
I have these and would recommend them.
http://www.ebay.co.uk/itm/Genuine-Land-Rov...SwvUlWtHjX
Post #502358 8th Feb 2016 10:06pm
mcma1
Have a set of those above to sell Whistle
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Andy
2014 Fuji 110 SW LS3
https://www.defender2.net/forum/post751233.html#751233
2014 Corris 110 SW
http://www.defender2.net/forum/topic40056.html
My old Xtech 90 build..
http://www.defender2.net/forum/topic15681.html
LS3 V8 build...
http://www.defender2.net/forum/topic49051.html
Post #502490 9th Feb 2016 7:31am
Ryderoo
England 2015 Defender 90 Puma 2.2 HT Santorini Black
Re: After-market seat options.
If I had to access under seat, I would have to use my mini Bahco socket set I keep in the cubby, I suppose the seat could go in the back to save it getting wet Thumbs Up Cheers Simon
I can explain it to you, but I can't understand it for you
1990 110 TD5 county, my first Land Rover - gone
2012 Discovery 4 XS SDV6 - gone
2014 Discovery 4 XS SDV6 - gone
2015 Evoque SD4 dynamic - Wife’s - gone
2015 Urban Truck 90 XS Santorini Black Hard Top - Reluctantly gone
2020 Discovery 5 Eiger Grey 3.0 SE - gone March 24
2021 Defender S D250 Santorini Black 110 HT - gone March 24
2023 Evoque P300e SE wife’s current vehicle
Post #502493 9th Feb 2016 7:36am
mcma1
I will never forget the night my alarm went nuts on the 90 and we had to take the seats out (Clio recaros cs at the time) what a complete PITA. Andy
2014 Corris 110 SW
LS3 V8 build...
Post #502495 9th Feb 2016 7:47am
Ryderoo
Too late now Rolling Eyes
Fingers crossed then Crying or Very sad Cheers Simon
Post #502497 9th Feb 2016 7:58am
Cupboard
I store all manner of stuff under the seats, tow rope, spare fuses, strops, snatch block, jump leads... couldn't be without access to them!
Post #502509 9th Feb 2016 9:07am
Riccarton
Thanks all - and given the alarm malarky I think I'll stick to lift out bases - I'm a coward I know!!
Like those Jay boy - very smart Bow down
Post #502512 9th Feb 2016 9:18am
Riccarton
Not in my price range you don't Rolling with laughter
Post #502520 9th Feb 2016 9:47am
Wild Card 90
England 2012 Defender 90 Puma 2.2 SW Indus Silver
Easy access to the left hand seat box is advisable.
The battery, and any additional fuses and relays that have might been installed there (on mine, the ones for the Ebersbacher heater), together with the jack are reasons enough.
But take a look in the right hand seat box, where the "main" fuse box is situated. There are another 25 fuses that might well need attention at some time or other. Incidentally, the seat boxes have small drain holes that should be kept clear. They also mean that water will come in if you drive as slowly as you should do in deep water, but will also drain them as soon as you are out.
Water in the electrics is probably one of the most common causes of modern vehicles malfunction. Blocked drain holes and drain tubes are often the cause. And from that point of view a Defender is no different.
Know where your fuses are. Know how to access them, and carry spares and a flashlight.
 1998 Tdi 90 SW,
2008 Td4 90 SW,
2012 2.2 90 SW,
2" raised Trailmaster/Terrafirma
Heavy Track Raids, 255 MT´s,
Recaro CS´s, anorak, wellingtons
Post #502553 9th Feb 2016 11:14am
LR Sam
If any one has any premium seats for sale - please let me know - ideal colours ebony/lunar! The ones on ebay have sold apparently.
Post #503002 10th Feb 2016 9:04am
JWL
Here's a curveball for those who want to fit aftermarket seats. I have put Mazda RX8 seats in my 110 and with it being a Td5 I didn't want to hamper access to under the drivers seat, the passenger one for me isn't such an issue with having an Anderson connector fitted for jump starting purposes.
When I fitted the drivers seat I fitted it on tapered seat runners as I also moved the seating position inwards to keep my shoulder off the doorpost and at the back of the runners I attached the runners to the seat box via a hinge point. In practice all I have to do is undo the fastenings at the front of the seat runners and the whole seat tips back onto the second row, giving me access to the underseat box.
Now while that works well with a Station Wagon as there's no bulkhead it can work with one as if you use the pivots at the rear, undo the front fasteners and use the seat recliner in the fold forward mode and the seat base will lift from the frontgiving you access to the underseat box enough for you to get in there Thumbs Up
Post #503079 10th Feb 2016 2:14pm
Butchers Boy
United Kingdom 2010 Defender 90 Puma 2.4 HT Stornoway Grey
[quote="Wild Card 90"][quote="Riccarton"]Know where your fuses are. Know how to access them, and carry spares and a flashlight.
One of the best (overlooked) pieces of advice I've read in ages!
I'll be checking my fuses and spares this weekend in all my vehicles Thumbs Up 2010 Defender 90 HT
The longer I live..... The better I was!
Post #503083 10th Feb 2016 2:27pm
RCMike
Thats interesting, i've literally just bought a set of leather RX8 seats and plan to install them this week-end. Good idea to hinge the back - i'll carry on pondering over the backets i need to fabricate.
Post #503283 10th Feb 2016 9:54pm
Riccarton
Thumbs Up Thumbs Up Bow down
Post #503289 10th Feb 2016 10:04pm
