![]() | Home > Maintenance & Modifications > After-market seat options. |
JAY BOY Member Since: 04 May 2010 Location: Not here Posts: 1706 ![]() ![]() |
I have these and would recommend them.
http://www.ebay.co.uk/itm/Genuine-Land-Rov...SwvUlWtHjX |
mcma1 Member Since: 16 Oct 2012 Location: Northern Ireland Posts: 2946 ![]() ![]() |
Have a set of those above to sell
![]() ![]() Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() 2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
Ryderoo Member Since: 28 Aug 2015 Location: South Oxfordshire Posts: 1666 ![]() ![]() ![]() |
If I had to access under seat, I would have to use my mini Bahco socket set I keep in the cubby, I suppose the seat could go in the back to save it getting wet ![]() I can explain it to you, but I can't understand it for you 1990 110 TD5 county, my first Land Rover - gone 2012 Discovery 4 XS SDV6 - gone 2014 Discovery 4 XS SDV6 - gone 2015 Evoque SD4 dynamic - Wife’s - gone 2015 Urban Truck 90 XS Santorini Black Hard Top - Reluctantly gone 2020 Discovery 5 Eiger Grey 3.0 SE - gone March 24 2021 Defender S D250 Santorini Black 110 HT - gone March 24 2023 Evoque P300e SE wife’s current vehicle |
I will never forget the night my alarm went nuts on the 90 and we had to take the seats out (Clio recaros cs at the time) what a complete PITA. Andy
Too late now
![]() Fingers crossed then ![]() I can explain it to you, but I can't understand it for you 1990 110 TD5 county, my first Land Rover - gone 2012 Discovery 4 XS SDV6 - gone 2014 Discovery 4 XS SDV6 - gone 2015 Evoque SD4 dynamic - Wife’s - gone 2015 Urban Truck 90 XS Santorini Black Hard Top - Reluctantly gone 2020 Discovery 5 Eiger Grey 3.0 SE - gone March 24 2021 Defender S D250 Santorini Black 110 HT - gone March 24 2023 Evoque P300e SE wife’s current vehicle |
I store all manner of stuff under the seats, tow rope, spare fuses, strops, snatch block, jump leads... couldn't be without access to them!
Riccarton Member Since: 10 Aug 2015 Location: Gods' Own Country Posts: 280 ![]() ![]() ![]() |
Thanks all - and given the alarm malarky I think I'll stick to lift out bases - I'm a coward I know!!
Like those Jay boy - very smart ![]() |
Not in my price range you don't ![]() |
Wild Card 90 Member Since: 03 Dec 2014 Location: Gerlingen Posts: 1060 ![]() ![]() ![]() |
Easy access to the left hand seat box is advisable. The battery, and any additional fuses and relays that have might been installed there (on mine, the ones for the Ebersbacher heater), together with the jack are reasons enough. But take a look in the right hand seat box, where the "main" fuse box is situated. There are another 25 fuses that might well need attention at some time or other. Incidentally, the seat boxes have small drain holes that should be kept clear. They also mean that water will come in if you drive as slowly as you should do in deep water, but will also drain them as soon as you are out. Water in the electrics is probably one of the most common causes of modern vehicles malfunction. Blocked drain holes and drain tubes are often the cause. And from that point of view a Defender is no different. Know where your fuses are. Know how to access them, and carry spares and a flashlight. ![]() Click image to enlarge ![]() Click image to enlarge 1998 Tdi 90 SW, 2008 Td4 90 SW, 2012 2.2 90 SW, 2" raised Trailmaster/Terrafirma Heavy Track Raids, 255 MT´s, Recaro CS´s, anorak, wellingtons |
LR Sam Member Since: 08 Nov 2012 Location: Yorkshire Posts: 236 ![]() ![]() |
If any one has any premium seats for sale - please let me know - ideal colours ebony/lunar! The ones on ebay have sold apparently.
Cheers |
Here's a curveball for those who want to fit aftermarket seats. I have put Mazda RX8 seats in my 110 and with it being a Td5 I didn't want to hamper access to under the drivers seat, the passenger one for me isn't such an issue with having an Anderson connector fitted for jump starting purposes.
When I fitted the drivers seat I fitted it on tapered seat runners as I also moved the seating position inwards to keep my shoulder off the doorpost and at the back of the runners I attached the runners to the seat box via a hinge point. In practice all I have to do is undo the fastenings at the front of the seat runners and the whole seat tips back onto the second row, giving me access to the underseat box. Now while that works well with a Station Wagon as there's no bulkhead it can work with one as if you use the pivots at the rear, undo the front fasteners and use the seat recliner in the fold forward mode and the seat base will lift from the frontgiving you access to the underseat box enough for you to get in there ![]() |
Butchers Boy Member Since: 10 Jan 2016 Location: Essex Posts: 426 ![]() ![]() ![]() |
[quote="Wild Card 90"][quote="Riccarton"]Know where your fuses are. Know how to access them, and carry spares and a flashlight.
One of the best (overlooked) pieces of advice I've read in ages! I'll be checking my fuses and spares this weekend in all my vehicles ![]() The longer I live..... The better I was! |
RCMike Member Since: 30 Apr 2015 Location: North Wiltshire Posts: 70 ![]() ![]() |
Thats interesting, i've literally just bought a set of leather RX8 seats and plan to install them this week-end. Good idea to hinge the back - i'll carry on pondering over the backets i need to fabricate. |
