![]() | Home > Technical > Who wants a Nanocom Evolution |
Zinke Member Since: 27 Jan 2009 Location: Scunthorpe Posts: 670 ![]() ![]() ![]() |
Depends how well you want to see it, i put mine between the gear levers and the seatbox, a bit of Velcro helps. But what ever you do dont hard wire it in, with it connected you can bypass the alarm and immobiliser and start then engine without the fob. The alarm will go off when you enter but it wont take long to disable it with the Nanocom! Pete. |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5117 ![]() ![]() ![]() |
So how many and when for an order?? Mike
So we need to encourage 5 more ![]() ![]() Edit...sorry 3 more now ![]() ![]() ![]() |
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 ![]() |
Defender SVX Member Since: 29 Jan 2009 Location: Co Durham Posts: 730 ![]() ![]() ![]() |
Reading the "what it does" text am I right in thinking it does little more than the scangauge11 for the puma?
![]() 16 Focus RS Nitrous Blue. 11 FFRR TDV8 Vouge SE Black Black. 08 DEFENDER SVX SOFT TOP (SUPERB) 08 DEFENDER 110 DCPU Stornoway grey (Overland Exploration Unit) 05 Fiesta ST 150 Van 04 Jaguar XKR 4.2 Supercharged V8 02 DEFENDER 90 TD5 (next years soft top project) 95 DEFENDER 110 CSW 300 TDi Phoenix black 95 DEFENDER 90 HT Monti Carlo blue COUNTY 300 TDi 67 109" SERIES 2a TUNED 200 TDI 64 DAVID BROWN 990 rat look 55 86" SERIES 1 |
Definately - it (from my memory) interfaces with ALL the on board systems on the defender allowing control over those systems. Basically (and you can see from previous threads on it i have commented) if its as good as it was with the TD5 then its by far worth it AND its reputation speaks for itself! Short of an Autologic system (at £12k) - its the best around. Mike |
Damn Mike, your quick
By interfacing and control you mean it can minipulatate a sensor to a generic setting in order to diagnose or to get you away? Can it also recode puma alarm fobs? I'm very tempted but can't help thinking that it may be better putting my money towards some Snap On diagnostics? Ca Formerly mao99999 16 Focus RS Nitrous Blue. 11 FFRR TDV8 Vouge SE Black Black. 08 DEFENDER SVX SOFT TOP (SUPERB) 08 DEFENDER 110 DCPU Stornoway grey (Overland Exploration Unit) 05 Fiesta ST 150 Van 04 Jaguar XKR 4.2 Supercharged V8 02 DEFENDER 90 TD5 (next years soft top project) 95 DEFENDER 110 CSW 300 TDi Phoenix black 95 DEFENDER 90 HT Monti Carlo blue COUNTY 300 TDi 67 109" SERIES 2a TUNED 200 TDI 64 DAVID BROWN 990 rat look 55 86" SERIES 1 |
Yes ![]()
Just curious, why snap on? The nanocom evolution is dedicated to Landrover/D2 TD5 and puma systems. ![]() |
The beauty of nanocom is it will work with all the LR systems, against just the odd item with the cheap(er) generic tools Mike
T1G UP Member Since: 08 Dec 2009 Location: Bath Posts: 3101 ![]() ![]() ![]() |
recently sold my snaop on 2010 solis..... not as good as a nanocom on a LR |
Roald Member Since: 31 Dec 2010 Location: Aarhus Posts: 31 ![]() ![]() |
If shipping to Denmark is not a problem, then I'll buy a td5 version
![]() Last edited by Roald on 31st Dec 2010 12:33pm. Edited 1 time in total |
daviec1 Member Since: 30 Nov 2010 Location: Ayrshire Posts: 246 ![]() ![]() ![]() |
Yep - done the research, seems like a good investment, so put me down for a TD5 version
