![]() | Home > Technical > Who wants a Nanocom Evolution |
CFB Member Since: 13 Sep 2007 Location: Bradford, West Yorkshire Posts: 803 ![]() ![]() |
Will this do a Disco TD5 or is just for a Defender please? Andy
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 ![]() |
If you dont have a puma then the TD5 pack will cover you |
T1G UP Member Since: 08 Dec 2009 Location: Bath Posts: 3101 ![]() ![]() ![]() |
i'd have a full pack D2 / TD5 / TD4 puma for £328 inc
I'm interested but perhaps need to know a little more. I want to be able to do things like change the BCU settings, adjust the air suspension ride height etc. If it can do all that with this kit then I'm in Andy
Glynparry25 Member Since: 16 Feb 2009 Location: Miserable Midlands Posts: 3015 ![]() ![]() ![]() |
Have put my thing up there^^^ Will PM you tomorrow morning
![]() Glyn ![]() |
I have it...........
next month will be ready an important upgrade .............. ![]() Nice toy I'm a Nanocom Evo developer, there is a lot of my work iside it, sssshhttt Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
Secrets safe with me mate ![]() ![]() ![]() |
Blindpugh Member Since: 14 Jun 2010 Location: Reading Posts: 40 ![]() ![]() ![]() |
This is spooky just looking at getting a Hawkeye or a Nanocom for my TD5 Defender but can not make up my mind which to get or which is best so anyone want to sway me.In the mean time I will put my name down for a TD5 package. He who dies with the most toys wins.
Steve B Member Since: 22 May 2009 Location: Warwickshire Posts: 589 ![]() ![]() ![]() |
Hello,
Can anybody tell me what this would do with my late 2000 TD5 Defender? I am pretty sure its the non flashable ecu, just wondering what parameters it would read. Than kyou, Steve |
Zinke Member Since: 27 Jan 2009 Location: Scunthorpe Posts: 670 ![]() ![]() ![]() |
You can read all the live data, change injector codes, change all security settings, pair up new remote fobs and all the abs/tc functions. Basicly you can do everything but re-write the fueling maps without having the chip changed in the ECU. The other option is to fit a post 2002 ECU with a different fuel mapping to suit the pre 2002 engine and then you can do everything you can with a post 2002 model, but its not as simple as it sounds. Pete. |
Thanks,
Any Idea what the live data is? Going to speak to the bank manager ![]() Steve |
Off the top of my head you can read
Engine rpm Road speed idle speed error Accelerator pedal readings in volts Accelerator pedal voltage Battery voltage Air flow Ambient air pressure Turbo pressure Inlet air temp Coolant temp Fuel temp Cylinder balances Im sure ive missed something on the list but that kinda covers the main ones. Pete. |
daviec1 Member Since: 30 Nov 2010 Location: Ayrshire Posts: 246 ![]() ![]() ![]() |
Might be a stupid question - but how / where do you guys recommend mounting one of these fancy units?
(having now discovered Scangauge is a no go for my TD5, this seems the next best option) |
